New LS1 Owners - Newbie Tech - 01 SS Y pipe question
afboom135
05-18-2012, 12:59 PM
I have a 2001 SS Camaro and I put on 1 7/8" headers with a 3" y pipe on it from Texas speed. The headers sound great but the y pipe hangs down way to far for my taste. It's literally just a few inches off the ground. I need to get a new one and was wondering what the best fitting y pipes are?
Blu99T/A
05-18-2012, 01:07 PM
I just installed mine and it tucks up tight. The only issue I have is that the merge hits my driveshaft loop, which is getting fixed this weekend with a Flowmaster merge.
Have you gotten under the car and tried adjusting it? The short pipe on the driver's side makes for alot of adjustability.
LS-ONE_DAY
05-18-2012, 01:26 PM
how many miles are on your car? You probably should have done motor mounts at the same time to things up a little better then the worn out rubber ones.
afboom135
05-20-2012, 07:21 PM
The car only has 69K on it. I've gotten up under it and tried to adjust it. I've even taken it to a shop but it just hangs done more then i want it to cause i really want to bring the car down 1.25" and I just won't be able to get it with that y pipe.
babbage1109
05-20-2012, 08:30 PM
It's a 3 inch diameter pipe. And one of the better tucking ones. Unless you go custom or oval pipe you aren't going to get anything drastically better
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
