Western Members - window motor fix
GARAGE_BUILT_Z28
05-18-2012, 06:29 PM
Where is a good place around the IE to have a drivers window motor replaced at I have the new motor just need it put in I've been hearing $75-120 in moreno valley hemet area is that about right?
ssteven
05-18-2012, 06:54 PM
Do it yourself....pretty simple.
GARAGE_BUILT_Z28
05-18-2012, 07:27 PM
I'm kinda tempted to do it lol..
RPD_Vette84
05-18-2012, 09:07 PM
all you need is a dremel, drill bit and rivets/screws. ive done about 20 of them.
GARAGE_BUILT_Z28
05-18-2012, 10:21 PM
Thanks I'm actually headed to harbor freight tools right now to go buy a dremel now lol..I firgure with you guys help and a write up I can do it myself and save the $75-120 I've been hearing its gonna cost me to swap it out
myws68u
05-18-2012, 10:47 PM
I replaced mine with the help of YouTube. I thought it was gonna difficult, but it is very simple.
RPD_Vette84
05-18-2012, 10:51 PM
should also look into the autotrix mod or build your own autotrix mod since its pretty much 2 relays and some wires.
oh yeahs heres a good write up that i learned off of.
http://shbox.com/page/windowmotor.html
GARAGE_BUILT_Z28
05-18-2012, 11:43 PM
should also look into the autotrix mod or build your own autotrix mod since its pretty much 2 relays and some wires[/url]
What does this mod do?
RPD_Vette84
05-19-2012, 02:06 AM
Um when GM designed the stoopid window motor setup on these cars they take power for the passenger window off the drivers side which is why these motors burn out so much. So basically the autotrix kit makes your passenger window get its own power off the battery instead of the drivers side.
GARAGE_BUILT_Z28
05-19-2012, 08:57 AM
Ok cool I'm gonna check into that...thanks guys I think I'm ready now to take this job head on lol
MJs1FastSS
05-22-2012, 02:34 PM
Add 10rwhp
You finish yet!? Bring it by ill do it just bring me some beer hahha
GARAGE_BUILT_Z28
05-22-2012, 02:41 PM
Lmao no I didn't finish it yet I took it off seen all that shit and realized I'm not ready to do it yet so I pushed on the harness for the motor and it started working again :-)
armkneez8
05-23-2012, 04:06 PM
I been driving for 3 years with non-working motors. I need to get this fix.
93camaro_zzz
05-23-2012, 05:34 PM
Same here.
GARAGE_BUILT_Z28
05-23-2012, 06:23 PM
Damm how do you go thru a drive thru lmao
Camaropar
05-24-2012, 02:48 PM
Ya seriously LOL, also when the cops pull you over? :P
Snowman2K1
05-27-2012, 11:10 AM
one guy quoted me at 350+ :jest: .. i was like forget that, have been driving with my window shut for years....
anyone in I.E. willing to do it for alot cheaper?
RPD_Vette84
05-27-2012, 01:28 PM
gees guys it takes like 20 minutes to do. ive done like 6-7 members window motors not including the many i have done myself. get an autozone one so if it goes out again its covered under warranty and you can get another one.
BigDaddyBry
05-27-2012, 03:01 PM
Add 10rwhp
If we only had 4 windows I could be at 400rwhp with this mod. :burn:
98TransAmAngryBird
05-27-2012, 07:28 PM
You should be able to do it with little to no problems. I did mine like 6 months ago for the first time and it went pretty smooth. Just take your time with the door panel when taking it off. goodluck!
armkneez8
05-29-2012, 11:57 AM
I don't go through drive thru's with my car...I use my wife's. lol! Cops have opened my door in the past. Does anyone have a rivets gun I can use? Thanks
94'BLKBRD
05-29-2012, 01:16 PM
The new motors normally come with nuts and bolts, so you dont have to use Rivets.
armkneez8
05-29-2012, 01:36 PM
I prefer the rivets. Doesn't the nuts get loose?
94'BLKBRD
05-29-2012, 01:41 PM
No, I add some Loctite to them.
armkneez8
05-29-2012, 01:56 PM
I see. Thanks
gorr4
05-31-2012, 02:31 AM
humm procrastination I know it well.. i think i had mine for 3 to 6 months before installing :P
but like every 1 sed it's not that bad of a job.
for me, removing the pop rivets, wear most of the pane.
i weld the nuts to the reg so i don't have to mes with trying to tape em & it will make the next replacement go way quicker! :)
But all the same If you or any one else needs help getting this done & Palm Desert is not to far away hit me up.
George
