BB70Chevelle
05-18-2012, 06:48 PM
94' mustang
25.5 chromoly chassis setup for bbc/glide built by DC Performance
Body:
Schoneck 6" cowl hood
Team z wing
Dc performance parachute mount
Front suspension/steering:
Team z K-member
Team z adj A-arms
Team z C/C plates
Team z travel limiters
Dmc motor/mid plate and engine limiters for bbc (have k-member and mounts for a sbc/lsx engine too)
Racecraft 2 inch drop spindles
Racecraft manual rack & pinion
Racecraft bump steer kit
Racecraft bolt in tubular steering column
Strange quick release hub
Strange 10 way adj struts
Strange coil over kit for struts with 12" 170lb springs
Grant steering wheel
Rear suspension/housing:
Trz double adj uppers
Trz double adj lowers
Trz spherical upper bushings
Trz anti roll bar
Afco double adj coil overs and springs
8.8 rear housing
Narrowed 2inch per side
Axle tubes welded and braced
Ford 9 inch housing ends
Team z indexing lower controll arm mounts
Trz double shear coil over shock mounts
Moser rear cover
Powder coated black
Fuel system:
Chilsed 5 gallon cell
Wheels:
15x3.5 street lites
15x10 4.5bs street lites
Brakes:
Baer ss4 custom front brakes
Interior:
Kirkey seat
Racecraft kirkey seat mount
Lightened stock dash
Dzus in center consule
Window net
Trunk mounted battery box with kill switch and charging post
All parts are brand new, some haven't even been installed on the car yet. Over $25,000 dollars invested in the chassis. Car needs motor, trans, wiring, plumbing, rear housing internals, and tires. Great start for someone looking to run in x275 or Ultra Street! Will take $12,500 for it!
Body:
Team z wing
Team z K-member
Team z adj A-arms
Team z C/C plates
Trz anti roll bar
8.8 rear housing
Moser rear cover
Powder coated black
Fuel system:
Wheels:
15x3.5 street lites
Brakes:
Interior:
Kirkey seat
Window net
