Generation IV Internal Engine - Please recommend me a cam!
View Full Version : Please recommend me a cam!
flynlow3
05-18-2012, 10:54 PM
This cam game is driving me nuts. I know just enough to make myself dangerous.... Enough said.
The car is a 2000 SS camaro. I have a blown head gasket so I plan to pull the 5.7 and use a 6.0L iron block that I was building for fun on the side. I started out with a lq4 bottom end. I bored the block .30 over. My pistons are flat top with no valve reliefs. I know the LQ9 has valve reliefs but I couldnt find any pistons with reliefs without getting custom ones. I decided I wanted to take advantage of the ls3 heads so I have a brand new set as well as a new ls3 intake manifold with injectors. The car is a manual 6spd with 3.42 rear end for now. My Goals are...I want a car that will be driven mostly on the streets and once or twice a year to the track. I like torque but I dont want it to the point to where I cant gain traction and all i do is spin the tires. The ultimate cam in my opinion would pull all the way from down low all the way up to say 6800/6900 RPMs. I dont like to spin above that. My valves are stock but I replaced my springs with comps 26926-16 kit. So given that information, I am worried about PTV issues with cams because of everything I have read. Can anyone recommend any safe cams that will take advantage of my free flowing heads and pull well throughout the rpms. If you could tell me what you think I should get and explain why, I would appreciate it!
1nasty86
05-19-2012, 12:00 AM
http://www.texas-speed.com/p-241-texas-speed-ls3-229236-624615-camshaft.aspx
Tainted
05-19-2012, 08:03 AM
Pat G will spec you a cam for $25. Best $25 you will ever spend
litle88
05-19-2012, 09:22 AM
Oooor you can call Comp for free and they can spec you one out too! It's not a black art. They have Ls techs that are cool to talk to. Just make sure you know the info on your heads and intake you'll be using.
DallasFMS
05-19-2012, 10:44 AM
Allan at Futral can spec you one as well for free.
http://futralmotorsports.com/customcamworksheet.asp
A.R. Shale Targa
05-19-2012, 03:25 PM
The large LS3 intake ports flow so well that the Ex. to In. ratio suffers a bit.
Consequently they respond to a bunch of extra exhaust valve timing. I'd call
Geoff Skinner @ EPS, or Pat G. uses EPS lobes as well. Something in the
226/238 @ .050" range with a bit wider 114 or 116 ls would help with the
wide 2500-6700 power band you are after. The smaller intake lobe should
help that 2.165" intake valve clear the true flat piston
Jrp1978
05-20-2012, 03:19 AM
Call comp
Gabriel Ray
Technical Consultant
COMP Performance Group™
3406 Democrat Rd.
Memphis, TN 38118
Toll Free: (800)999-0853
Fax: (901)366-1807
gray@compcams.com (amick@compcams.com)
www.compperformancegroup.com (http://www.compperformancegroup.com/)
He just did my cam in my G8 and I friggin love it! Tell him James Pruitt sent ya ! He is super nice and will more than willing to help ya out !
flynlow3
05-20-2012, 05:34 AM
Call comp
Gabriel Ray
3406 Democrat Rd.
Memphis, TN 38118
Fax: (901)366-1807
This Gabe guy is A.) extremely nice B.) More than willing to help with my build and specing the cam. C.) KNOWLEDGABLE! I talked to him yesterday and he is the first guy who didnt act like he was in a hurry to get me off the phone. Everyone else I spoke with quickly said you shouldnt have any issues with ptv clearance when I would! He explained to me how the contact points are different between the 6.0L and the LS3 block when using the LS3 heads. You can't get by with as large of a cam with the 6.0L when running l92/ls3 heads. I have since decided I wanted to take advantage of my heads so he put me in contact with diamond and a set of pistons are my next move and I am planning on running the 54-469-11 comp cam.
Comp owes Gabriel for my business!
Jeff
Jrp1978
05-20-2012, 08:14 AM
I will second that on .... having my business !
Comp got good peeps over there !
07sick22
05-20-2012, 09:47 AM
i agree with this:headbang:
DallasFMS
05-21-2012, 11:44 AM
We can spec a cam for you at Futral Motorsports. Follow the link below to get your car information to Allan so he can spec a cam for you.
litle88
05-21-2012, 12:28 PM
A agree with futral and Gabriel is also one hell of a guy as well he also assisted me in getting the right parts for my FAST Ls3 setup. He knows his stuff and is a pleasure to talk to.
CAMSTER
05-22-2012, 11:12 PM
Patric G Camhelp@Guerragroup.com
