Tools & Fabrication - PlastiDip on jack stands?
View Full Version : PlastiDip on jack stands?
Stu_x24x
05-19-2012, 11:00 AM
I've seen those plastic top covers for jack stands and was curious if something like PlastiDip could be used on the stands instead. I'm just looking for something to help with grip and help prevent scratching things up under there. Thoughts?
Pseudonym
05-19-2012, 12:26 PM
My friend did it. He only did one coat and it just kind of came off after the first use. I guess if you put multiple coats on, it might work.
jetsbaby
05-19-2012, 01:33 PM
Harbour freight sells them for cheap..
Stu_x24x
05-20-2012, 04:02 PM
I guess I might as well try the PlastiDip to see...and if it doesn't work out I can swing by HF to snag some up. Thanks
Blasko
05-20-2012, 04:33 PM
I think no matter how thick you apply plasti-dip, it will wear off. I usually just grab some cardboard or something and stick between.
Mike52
05-20-2012, 06:58 PM
Folded shop rags works for me.
01350ss
06-09-2012, 07:41 AM
another method is those rubber disks that some people use to grip the top of a jar to help them spin it off
WheelsUp84z
06-13-2012, 05:06 PM
The roll on or dip types of the plasti-dip would work. the paint/aerosol style probably wont hold up to contact.
bigbadblack93z
06-14-2012, 03:58 PM
try the spray on duplicolor bed liner and avoid the plastidip, either one will still flake off after a time or 2 though.
chasgiv3
06-14-2012, 04:59 PM
I just use shop rags myself. The Harbor freight ones will work if you want to get fancy.
http://www.harborfreight.com/2-piece-rubber-pads-for-jack-stand-95952.html
NEXRACE
07-10-2012, 02:17 PM
x2 on the shop rags, quick & easy, i'll get around to the harbor freight ones some day, lol
btlegacy
07-13-2012, 12:46 PM
shop rags or old tool box foam or anything rubber basically around the shop
99Bluz28
07-15-2012, 02:46 AM
Just get some Prothane urethane Jack Stand Pads and a jack pad, that's what I've been using for yrs.
Jim Shoulders
07-26-2012, 02:35 PM
I use some old thick astroturf on the floorjack pad and wrap the candlestick tops with astroturf and tie it on with safety wire or zipties . Works well and last a decent length of time. Hockey Pucks work well for low dollar motor/mount pads and jacking/jackstand pads if you have the style with large flat tops. They can slide on the jackstand application.
Mr. Hyde
07-26-2012, 03:31 PM
Just drive it up on the curb like my neighbors. No need for a pesky jack or stands in that case.
shayanaz
07-26-2012, 11:48 PM
plasti dip peels off
