Stereo & Electronics - Installing 145 amp alt.
Marios_98z
05-19-2012, 12:41 PM
So my lights flicker so I decide I'd switch out the alt for the truck 145 amp my question is it necessary to run a second wire to the battery if so what size wire should I use?
sjsingle1
05-19-2012, 08:03 PM
the BIG 3 is always a good idea.....even with stock alt
ranman02ta
05-19-2012, 10:13 PM
i did not, and it work without a issue.
Marios_98z
05-19-2012, 10:52 PM
Did a bit of reading up on this doesn't sound like a bad idea!!
ranman02ta
05-20-2012, 09:33 AM
I found a KG3 alt on line. bolted right up and changed the single wire that clips on to it.
fixed the pulsating lights for 2000 miles now
sjsingle1
05-20-2012, 09:54 AM
i am sure there is a write up on here somewhere........
Marios_98z
05-20-2012, 01:12 PM
There is plenty of write up but everyone does it there own way!! I guess I will too!!!
jlcustomz
05-20-2012, 01:56 PM
I swapped my F-body alt to the 145 amp truck type last year. No complaints, had to notch a spot in my custom made brackets. In my ls1 swap back in 02', I ran a 2nd wire from alt to battery. Recently read somewhere this isn,t the best idea???
http://i1094.photobucket.com/albums/i450/jlcustomz1/DSC00603.jpg
youcancallme29
05-22-2012, 10:20 AM
Not that its a bad idea, its just that its pointless to have two wires IN MY OPINION when youve upgraded to the bigger gauge wires it just clutters the engine compartment. Some people will do it differently as long as it is upgraded there is no wrong way.
Floorman279
05-22-2012, 11:26 AM
all i did was get a remy 145 amp truck one from advance auto.....didnt do anything else.....lights no longer flickered
beyonddisturbed
05-22-2012, 02:40 PM
i replaced my battery wiring with the big 3 from innovative wiring and added a 145 amp alt i picked up from a salvage yard. the wires are perfect length. eliminated all my electrical problems ie flickering, dropping voltage at WOT and she never drops below 13 v.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
