Generation IV External Engine - stock maf limite
35th camaro
05-19-2012, 08:56 PM
i have a 2002 camaro with a 402 stroker, wondering what is a stock maf capable of hp suporting. i have more to add after i have a few comments of people that have seen it first hand.
BOBS99SS
05-19-2012, 09:02 PM
Honest at one time i heard it was good up to 500 hp, hopefully i will be able to give ya more info on that real soon lol
35th camaro
05-19-2012, 10:52 PM
i am curiose because i made 457rwhp last year with a truck maf(i think 85mm),ls6 intake,stock t/b and slp lide.after 6000rpm i lost 100rwhp in the next 500rpm and this year i have a 100mm maf with 102 intake, 102 t/b 104 lide and having bucking and tuning problems, wide open trottle feel strong,(no dyno test yet) my tuner has ask me to put on my stock ls1 maf to try, drivability is verry good with stock maf, but my but-dyno tells me that it is not as stong as the 100maf. looking for the limits of the stock maf(ls1), will be putting on dyno in 2 weeks at a show we are organizing, would like to kno at what hp the stock has max out before, what max flow number should i see on my hp tuner.
bwkmaro
05-19-2012, 11:18 PM
does your 100mm maf have a screen? because that will cause alot of turbulence and disrupt the maf signal flow alot of people disagree but i have come across problems without it. and there is a formula to figure out the max airflow something a certain size can flow i just have to find it in my notes somewhere from efi school
35th camaro
05-19-2012, 11:33 PM
i did put a screen, it is just i don't want to wast time tunning the stock if i am loosing a good amount of hp, i am willing to sacrafice a small amount for drivability, on the stock maf the most i have seen is 10700 hz at 6500rpm, is there still room to grow
35th camaro
05-19-2012, 11:46 PM
my goal is to get to 500rwhp, like i said before i was at 457rwhp at 6000rpm before the fast 102 intake and t/b. 100maf. 104 lide and 4'' exauste. and the power drop of very fast loosing 100rwhp by 6500rpm, that is why i changed the intake set-up and exauste, my cam has always been 236-242 at .050. in the .650 lift range. i figured something was maxing out past 6000rpm.
35th camaro
05-19-2012, 11:53 PM
i had hughe probleme with the 100mm maf, had it in the stock location and sensor plug at the 3 o'clock position, i then put it in the 11 o'clock position and was much better, after i put in a screen and helped some more, drivable but bucking. i am thinking that at low speeds the air flow is not all going acrosse the sensor in the large maf. velocity is low.
Dyno Junkie
05-20-2012, 08:57 AM
Simple, get rid of the MAF and go speed density!:guns:
bwkmaro
05-20-2012, 10:27 AM
^ not a bad idea
35th camaro
there is a diference in temps here, could be 45 somtime 95, different in altitude, valley and mountains
Double J
05-20-2012, 02:51 PM
I've heard this recommendation before when asking bout PORTED MAF ENDS, What is speed density? How is it installed? Thanks
Double J
05-20-2012, 02:56 PM
Hi-which brand 100mm MAF do you have? looking to purchase one for my 418 motor but the one I found on speed Inc is descreened, Thanks
35th camaro
05-20-2012, 06:54 PM
maf is from texas speed and has no screen
35th camaro
05-20-2012, 06:58 PM
but i did add a screen on the exite of the air lide, i took a screen from a truck maf and it fits perfectly into the 104 lide
Dyno Junkie
05-20-2012, 07:28 PM
That's not a problem, just needs a proper tune and all will be good:judge:
35th camaro
05-20-2012, 07:42 PM
would like to stay with maf.
z28241
05-20-2012, 08:49 PM
OP, is ur tuner pretty flexible, perhaps swapping them between runs..?
35th camaro
05-20-2012, 08:57 PM
i am tunning by e-mail. we have a dyno comming to our festival car show in 2 weeks, will try both maf, trying to get it figuered out before the dyno arrives
z28241
05-20-2012, 09:07 PM
gotta say its little weird to see 100 h.p. loss after 6k during the next 500rpms?..something doesnt sound right about that..sorry if i missed it, but what injectors are u running?
35th camaro
05-20-2012, 10:43 PM
42lb injectors,
z28241
05-21-2012, 11:32 PM
And it wasnt experiencing any "knock" as well, right? just asking because im sure those injectors werent maxed..
35th camaro
05-22-2012, 04:55 AM
no knock and injectors are at 62%.
z28241
05-22-2012, 09:57 PM
something is definitively up..
