Fast 102 Fuel Rails leaking! PICS Inside!
Old 05-19-2012, 09:47 PM
r4dio78's Avatar
Exclamation Fast 102 Fuel Rails leaking! PICS Inside!
k so i put on my fast 102 today and i also have the billet fuel rails and i got everything tightend up and im leaking fuel from this little hole from th AN fitting! wtf! am i missing somthing or did i do somthing wrong? i also put some tread seal tape and that still didnt work. can somone help! i couldnt get pics from the rear, but heres the front.
Old 05-19-2012, 09:51 PM
Bramlok's Avatar
Are they FAST fuel rails? And if so, did the fuel line come with it?
j99fbody's Avatar
bad fitting, i had a fitting do the same thing so i got another one and it fixed it.
Old 05-19-2012, 09:58 PM
r4dio78's Avatar
ya there fast fuel rails i order the #54028 and FAST 146032 together.
Old 05-19-2012, 09:59 PM
r4dio78's Avatar
what did you do return the fuel line and they sent you another set?
Old 05-19-2012, 10:05 PM
badazz81z28's Avatar
I suggest sealant (liquid or thin putty) rather than the pipe tape.
Old 05-19-2012, 10:09 PM
r4dio78's Avatar
k i guess ill pull the rails off again. is there any brand you suggest?
Old 05-19-2012, 10:32 PM
I'm pretty sure I used Permatex Thread Sealant on my AN fittings. Ill check.
Old 05-19-2012, 10:49 PM
Go On 3's Avatar
bad fitting/line, shouldn't be a hole there .. if you bought this new i would be calling for a replacement. no thread sealant will fix that and if by chance it does its just a band-aid
Old 05-19-2012, 11:52 PM
r4dio78's Avatar
the hole is suppose to be there, idn y i think its stupid that they did that. anyone else that running the same set-up???
Old 05-20-2012, 06:18 AM
Old Geezer's Avatar
Question ???
1. You DO NOT use pipe dope or tape, on an AN fitting.
2. That "hole" is a lock pin to lock the fitting together.
3. It appears that you have a cheapo crimped hose fitting that's in a bind. Leaving that braided line lying on the surrounding parts will chew them up.
4. Can't tell from the first pic, but it looks like the fitting is screwed onto the rail fitting so far that it's bottomed out. Y/n?? WTF did you use to tighten it, a pipe wrench??
4. What is that squeezed out between the rail and the fitting? An o'ring?
Old 05-20-2012, 06:32 AM
LS1MCSS's Avatar
A lot of AN fittings have that hole. This one is defective on the inside. Just get a new fitting or line, as required. DON'T use any sealant. You should never use sealant on a flare fitting.
Old 05-20-2012, 08:00 AM
TransamGCS's Avatar
op just call fast and tell them its leaking from the pin hole they'll probably send you another one, do not use pipe sealant or tape for the an fittings, with my fast fuel rail where the fuel line hooks up to the rail i had to really tighten the **** out of it to stop leaking from the threads
Old 05-20-2012, 09:08 AM
That's MISTER MODERATOR
Paul Bell's Avatar
This old geezer agrees with that old geezer.
AN fittings go together dry. The wrench marks make me think you over tightened it. These do not get gorilla tightened.
Old 05-20-2012, 03:14 PM
SweetS10V8's Avatar
And your using the wrong tool. Those look like plier marks!!! If it were sent back for warranty , youll probably have to explain the marks. A wrench is all you need, and it doesnt have to be super tight.
Old 05-20-2012, 03:26 PM
Paul Bell's Avatar
Or vise grips.....
Old 05-20-2012, 05:10 PM
r4dio78's Avatar
k well i took off my fuel rails today, and yes it was vise grips...... yesssss..... i knooooooo....stupid thing to do. but i needed my car running asap cause its my DD and a friend of mine had my crescent wrenchs, so finally retightend everything back up, so far so good no leaks. i sware this always happends to me when somthing goes so smooth n perfect SOMTHING ALWAYS HAPPENDS! FML. thxs everyone.
Old 05-20-2012, 07:16 PM
fastazzls1's Avatar
And get some AN wrenches god you fucked that fitting up
Old 05-20-2012, 07:29 PM
r4dio78's Avatar
its not really that bad. nothing that touch up paint cant do.
Old 05-20-2012, 07:35 PM
crainholio's Avatar
Using the wrong tools might possibly have something to do with your "luck" here...
Quick Reply: Fast 102 Fuel Rails leaking! PICS Inside!
