Kooks header questions
WARNING! Bad Seller Alert
Im building a 427 blown 15lbs of boost car. I know that on a blown car the exhaust plays a good roll. What size of header should I get and what does step headers mean? Thanks for you're help.
At the very least I would do a 1-7/8" to 2" stepped header. Stepped means, that approx. 1/3 or so the way down the primaries, the tube length switches from 1-7/8" to 2". In most cases, this will increase mid-range torque, and top end horsepwer.
You might even think about a 2" to 2-1/8" step if you have the room.
So wich of the 2 would be better to the big cubes and blower. I just got my stroker and its 4.125 bore and 4.125 stroke. Thats not a 427 I know. Its more like a 441. That's what happens when you let you're friends order for you. Thanks for your help.
