max hertz on a stock ls1 2002 maf
Old 05-20-2012, 07:11 PM
35th camaro's Avatar
Default max hertz on a stock ls1 2002 maf
i am looking for info on the stock maf ls1 2002 camaro, what is the max hertz could i see on my hp tuner, how do i kno if it is maxing out, and also what rwhp limite have you seen from the stock unit, i have a strocker 402 with aprox 500 rwhp
Old 05-20-2012, 07:30 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
98 cars go to 11,250Hz, later years go to a full 12,000Hz I think. Max airflow is somethink like 67-67Lb/min of airflow. Go log your car and see if you reach that number, if not you havent maxxed the MAF. Stock MAF will go higher than 500hp.
Old 05-20-2012, 07:35 PM
i have seen 10600 hertz at around 6600 rpm, but engine will spin easy to 7000, havent tried yet because a/f wasn't right.
Old 05-20-2012, 07:42 PM
ddnspider's Avatar
Yea, you're not maxxing it yet. Log lb/min from the MAF too and that'll give you an idea. Somepeople use that to ballpark engine HP. I max my MAF at ~4500rpms
Old 05-20-2012, 07:48 PM
i have a 104 lide, 102 fast intake and 102 trottle body, the stock maf won't hurt my hp until i max it out???, tell you why i have the stock maf now before you ask. i have been trying to get ride of some bucking with the 100 mm maf i had and i could not. my e-mail tuner told me to try my stock maf to see, and almost no bucking to speak of. just that my but-dyno tells me i have lost a bit.
Old 05-20-2012, 08:04 PM
ddnspider's Avatar
stock MAF definitely sounds like the restriction in your intake track, but I don't know the rest of your setup. I havent seen much of a before/after comparison from swapping MAF's only. I would say if you already have the bigger maf, and the rest of the setup is big like the 102 stuff you posted, then I would focus on working out the bucking.
Old 05-20-2012, 08:06 PM
ddnspider's Avatar
PS, I've seen people try this if they want to see if they have an intake restriction. Log your MAP and make a pull in the car. If you do not stay at ~105kPa, then you have an intake restriction because youre not using all of the available air in the atmosphere.
Old 05-20-2012, 08:51 PM
that is why i want to kno the max that the stock can take, not saying that it is a restriction but i do want to find out, have been trying to tune the large maf with 2 tuners, it was the ideal of the 3rd to try a diferent maf to see if the bucking would go, this is all by e-mail tuning
Old 05-20-2012, 08:53 PM
will try the map logging tomorrow
Old 05-21-2012, 08:18 AM
check one of my logs and at 6170rpm i was at 96kpa, check before i started the car and was 101kpa. at one point on a acceleration log it was at 101 then started to drop down to 96 as rpm went up.
Old 05-21-2012, 08:24 AM
ddnspider's Avatar
You should be seeing 100+ for most of the run with your intake setup. I know you said you had bucking with the 100MM MAF, but is it okay under WOT? I'd be curious if you swapped that on and made another pull, if you'd suddenly see it stay at 100+. Of course this assumes the tune is acceptable for the new MAF at WOT.
Edit...I should clarify. Are you just a bolt-on car or do you have heads/cam too?
Old 05-21-2012, 08:37 AM
i do have a log with the 100maf, and i seen were it is at 98-99kpa at wide open trottle at 6400rpm.
Old 05-21-2012, 10:24 AM
ddnspider's Avatar
Are you a heads cam car? It sounds like the MAF was a slight restriction but youre still not using all the available air in the atmosphere.
Old 05-21-2012, 03:03 PM
have patriot stage 3 heads, pacesettre long tube and off road y into a 4'' exauste, cam is 236-242 at .050 and 650 lift
Old 05-21-2012, 03:57 PM
ddnspider's Avatar
Are you using HPT or EFI Live?
Old 05-21-2012, 04:06 PM
Hp tuner
Old 05-21-2012, 04:59 PM
ddnspider's Avatar
Hp tuner
Ah, I use EFI Live. Otherwise, I would have looked at your logs. You just need to try and gauge from the logs if it appears like a significant restriction. I would think you're probably okay, but it sounded like with the stock MAF you were at 96kPa and then it went down, whereas the 100mm stayed around 98-99.
Old 05-21-2012, 07:05 PM
it is exacly that, is that much of a restriction3-4kpa
Old 05-21-2012, 07:26 PM
ddnspider's Avatar
Im not experienced enough to say yes or no, someone else would have to chime in. I would log airflow from the MAF in lb/min and compare the 2. If you're flowing serveral lb/min of airflow more, than youre making a good amount of power from changing to the 100mm.
Quick Reply: max hertz on a stock ls1 2002 maf
