Eastern Members - plug change, near roanoke va
98FormulaZW
05-21-2012, 01:21 AM
im looking for someone near roanoke va to change the plugs/wires in my 98 formula firebird
mjs1012
05-21-2012, 06:58 AM
To be honest just do it yourself. All it takes is a 5/8 deep socket, time, and a lot of patience.
98FormulaZW
05-22-2012, 01:03 PM
dont i need a lift? that seems to be what everyones been saying
00NBMformula
05-22-2012, 04:24 PM
U need to jack the car up a little to get to the #8 without removing parts, other than that u can get them all with a socket, extension and ratchet
mjs1012
05-22-2012, 10:19 PM
Just lay up on the intake and pull the coil in the back and get the plug out. I used a swivel socket extension and it worked fine.
baalic
05-22-2012, 10:30 PM
You should be able to get most of them with little to no effort, number 8 if you have ramps, use those to get under your car, or just jack it up and get the number 8 from below, hardest part is pulling factory wires off without breaking them...I would buy an extra set while your at it, 2 out of 3 times ive done it now, I have broken at least 1 wire.....
baalic
05-22-2012, 10:31 PM
OH and I didn't use any Swivels, but my knuckles are always getting busted
jaxcam02
05-22-2012, 10:35 PM
Do it yourself, drivers side is cake and the passenger side is cake except the number 8 plug which you can remove the coil bracket and air system pipe from the exhaust manifold.
This link helped me (has pics and useful hints)
http://www.installuniversity.com/install_university/installu_pages/freshman_year/spark_plug_and_wire.htm
southpaw0314
05-22-2012, 10:38 PM
if you take off the coil pack bracket it is alot easier to get to the #8 plug then the other methods listed.
02 NHRA
05-22-2012, 10:43 PM
I used the same link when I did mine the first time and it wasn't that bad... I dont have bear claws for hands either though lol.
Tribal
05-23-2012, 08:35 AM
I did mine in 2 hrs first time. All u need is a plug socket. Magnetic would be preferred. A 3" and 1.5 extension only removed the egr filter on passenger side and used ramps.
98FormulaZW
05-23-2012, 12:51 PM
thanks everyone!! i didnt know it was that simple, ill do it myself! appreciate the input
yahoodeno
05-23-2012, 01:04 PM
If you take the psssenger side coil pack off it makes it so much easy. I sprayed WD40 on the plugs so none of the stockers gave me any problems none broke that way
BlackScreaminMachine
05-23-2012, 01:21 PM
Coil pack needs to come off for me, I'm not Asian. STOCK wires should get stuck on and probably will break. I spend more time dicking with the boot metal covers that I chuck those too. Order a set of LS6 or MSD (which ever your fancy)
Like said 8 sucks but do able, they all are. Just patience. Also if you never took the coil packs off, at the back near the rear of passanger side of the motor, the last coil pack had a double stud. So its off with the nut, bend back the metal braket, and then its a nut/stud combo. DO NOT re install. Throw it out.
