Drag Racing Tech - What would you recommend for options on a trailer?
mike13
05-21-2012, 10:58 AM
I'm shopping for a flat bed trailer for my trans am, what would you recommend or wish you might of considered when getting a trailer?
99'CajunFirehawk157
05-21-2012, 11:06 AM
Just got mine Saturday, trailer fender height can not exceed 9" or your doors cant open without hitting the fenders! Also make sure the trailer ramps/deck is at a height low enough so the front bumper of you car will clear, the longer the ramps the better, 5ft or 6 even better, also consider the rear of your car coming off the trailer too, its low as well.
My 18ft w4ft dovetail w/5ft ramps
https://lh3.googleusercontent.com/-OVrqz2SSUGU/T7f9T3FQsVI/AAAAAAAAIfk/nIbrajo0_Sc/s720/IMG_2705.JPG
dschmittie1
05-21-2012, 11:31 AM
18Ft with Dove tail is the way to go.
http://www.econotrailer.com/
They make a nice trailer for a good price. My buddy has one of there open deck trailers and it is nice.
I bought Fireball's old Closed deck Better Built trailer and it is a tank.
5.3LJimmy
05-21-2012, 12:45 PM
18 foot with a 4 foot dovetail and 6 foot long ramps. A spare tire and four ratchet straps with two axle straps. Also make sure you get trailer brakes.
dschmittie1
05-21-2012, 12:48 PM
Oh and brakes on BOTH axles
deerslayinrednek
05-21-2012, 12:50 PM
like everyone else says a 4' tail would be nice. Mine is 2' and kinda sucks to load the car on. I'd suggest hooks on the front and rear of the trailer for strapping the car.......Be sure to get a little more trailer than you actually need, you wont regret it
mike13
05-21-2012, 02:08 PM
thanks guys, very helpful information
mike13
05-21-2012, 02:43 PM
what's your opinion on tilt bed style trailers?
http://seattle.craigslist.org/oly/ctd/2988024086.html
Mighty Whitey
05-21-2012, 02:53 PM
A couple years ago, i did a timing Chain swap on an '05 Nissan altima, and took this trailer in on trade for the labor:
Its a home built closed floor "roll back"/tilt trailer that works awesome.
http://i2.photobucket.com/albums/y35/indigoblue94/6e401f9e.jpg
http://i2.photobucket.com/albums/y35/indigoblue94/ef570db4.jpg
Has an 6" stroke, enerpac port-a-power cylinder to lift the bed, a small hydro pump with an integrated 12v motor, and an old-skool warn 8000lb winch, with drum brake, and is free-spool capable.
The front valance on my car is about 3" off the ground, so I built some 5' ramps out of 1 1/2x 3/16 angle to help get the front end on easier.
It looks rough as cobb, but This trailer pulls like a dream... topped out, on the governor at 112mph in my dodge, you couldn't even tell the trailer was back there.
I love the load capacity of the Dayton style wheels, but 7x14.5 10ply tires are getting tough to find these days (7.5x14.5 is common)
BlackScreaminMachine
05-21-2012, 02:55 PM
Not my cup o' tea. Also like techincally the ability to get underneath if I had to do somethingto the suspension. Solid wood deck makes to tough. My buddy had one and is dove tail with the metal ramps worked great.
I would be getting it just like the others on this post.
BADD SS
05-21-2012, 06:12 PM
IF the ramps are long enough, you dont need a dove tail, and it's actually better if you ever have to back over uneven ground... I built my 40' two car trailer how I wanted it, no one made a decent two car for under $10,000, steer clear of the ebay sweet rivers farms trailers and the like. They are made terribly. My ramps are 7' long, slide in, so you never have to lift more than half the weight, lock in when you pull them out. Usually the cheaper trailers are all crap... dont go less than 18'..
mike13
05-21-2012, 06:34 PM
thanks
