**UPDATE 3..have my answer**Blew engine..I think..turns over but won't fire...video
173,000 miles on my stroker....so I can't complain.
I was doing a very high speed run on the highway yesterday. Out of nowhere the engine just shut off dead like I turned the key to off. No noise, no vibration, nothing.......
I pulled over and the temps were 240*F and there was white smoke pouring out of the oil fill cap when I took it off.
Engine turns over but its struggling, not smoothly turning over. But it will not fire.
Any ideas why it won't fire? I'm thinking my oil pump failed during the run....
Engine comes out this week. It'll be rebuilt immediately into a 441ci LS7 top end.
VIDEO:
UPDATE....video...turning over engine. Its not just one speed, it sounds like it has a little struggle spot.
http://s263.photobucket.com/albums/i...idstarting.mp4
UPDATE 3....Video.........Internal Part is broken..........
Video is short......put the new Crank Sensor in. It fired like it always has when I just bump the key. BUT...it made an instant loud, CLACK, CLACK and stalled by itself. I did not try again.
I'm guessing broken rod.
There's a picture below of the old Crank Sensor....it has about a 1mm deep groove across it.
So, engine is coming out.......getting rebuilt. SUCKS, its just a bad time. I was about a week away from getting my new (used 2008) Merc E63 AMG.......now I'll have to wait maybe 6-8 months Oh well........pay to play. I got to play for 10+ years with this great engine that ARE built. Hope my 441ci lasts this long.........
VIDEO:
VIDEO:
VIDEO:
Pull a sparkplug, plug it into its coil wire and have someone crank the engine over while you look for a spark from the plug. That'll tell you right quick if you're getting spark.
Hope that's all that happened! And yeah, there is a fuse for the ignition under the hood (on my Silverado there is anyways).
I thought I'd be pissed about this happening some day.....but its a great reason to pull it and rebuild it. Its old..... Just sucks because it ran so damn good.
I'm still thinking maybe the oil pump failed.
Do you know what happens when an engine is at high rpm and oil stops flowing....?
I mean does it usually end up in a catastrophic failure with parts breaking and noise. Oil pouring out of the crankcase. Will it still turn over if it shuts down because of oil starvation?
Meh.. when it's at high rpm and oil stops flowing, it usually just seizes up before parts break. If the oil pump did fail, it probably seized the bearings and rings momentarily. Once the engine cooled somewhat, it freed itself and was able to turn over. Now, as far as the white smoke pouring out of the oil filler cap, that's a sign of major blow-by. If the engine was in the middle of seizing, the rings were getting pliable and lost any shape they had, letting oil get by the rings and into the combustion chamber, and gas and burned oil from the combustion chamber into the crankcase, thus giving you the abundance of white smoke.
How high were the rpms when it let loose?
It shut down very quietly. No other bad symptoms.
You could have a bad fuel pump. If it has lost fuel pressure I don't think it will even try to fire. The first thing it does before you start it is prime the fuel pump. Probally the white smoke is just from the high speed run you were doing.
I have to get back over there tomorrow and check the fuses, then see if the rockers are moving to see if the timing chain broke. I'll pull a plug to check for spark while cranking.
Not always, but if you're turning any decent RPM when it happens it's a good chance. Doubt its a timing chain, every time the motor turns over you would run the valves into the pistons and that noise would be obvious.
At full power an engine will have no problem overcoming the friction caused by no oil pressure.
If you have an oil pressure gauge, you should see pressure when cranking, or just after you stop cranking breifly.
A quick way to check if the ignition relay went is to swap it with the fan relay right next to it. If it fires, you found your problem. Both are located in the fuse panel behind the driver side headlight.
