1985 LS1 Trans Am
1985 LS1 Trans Am
Year: 1985
Make: Pontiac
Model: Trans Am
Price: $4500
Mileage: 65000
Private or Dealer Listing: Private Listing
Location (State): OH
Color: White
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Engine:
Stock LS1 bottom end and stock LS1 heads
Comp Cams 54-601-11 cam. Specs 564/547 lift with 227/247 duration
New Lunati dual valve spring kit.(Have receipt)
New Roller lifters. (Have receipt)
New Head gaskets and head bolts.(Have receipt)
New Water pump and gaskets (Have receipt)
SLP double roller timing chain
Edelbrock Victor Jr intake
Demon 650 carb
MSD 6010 Ignition Controller
MSD Ignition wires
Shorty Headers with no cats connected to a Borla exhaust
New aluminum dual core radiator.
Trans:
Rebuilt TH350 with a 3000 converter
Rear end:
Stock 3.24 gear ratio
The car is in good shape. Has a 3 inch hardwood fiberglass bolt on hood. I also have the original. A couple scratches here and there are a couple spots on the trunk and the back bumper were the previous owner put bondo on it. Car runs and drives great. Speedo works as well as all the lights and signals work as they should. Car starts with the key and the fuel pump needs turned on with a switch. Power windows, locks and steering. The cars weight 3,300 pounds. It runs 13.5 in the ¼. With a good set of slicks and a gear change you should be running high 12’s.
The bad:
No heater/ A/C box. I have the parts for the heater box. Also the head lights do not pop up on there own. You have to hand crank them.
Any questions please email me on here or at mrmatt47@yahoo.com or call (330)284-7741
Asking $4,500 or best offer
Tons more pictures. Just ask. Willing to separate motor
The site is not letting me put up pictures here is the link for more pictures
http://www.racingjunk.com/Pontiac/26...-Trans-Am.html
sorry for the inconvenience
