Changing from 6.0 to 5.3, do I change it in HP?
Old 05-21-2012, 07:23 PM
MillsMotorvation's Avatar
Default Changing from 6.0 to 5.3, do I change it in HP?
The 6.0 ran great, Ive change the engine to a 5.3, do I go in to the settings and change the cyl air from OHV 6.0 to OHV 5.3? Will there be alot of difference in the way the car ran. All the parts from the old engine are in the 5.3 cam, push rods,...ect. The 6.0 came with 317s, the 5.3 came with 862s I ported the 862s to get better flow, added studs, and LS9 HG, but all the rest is the same both engines are 2000 year.
Old 05-22-2012, 09:07 PM
flame's Avatar
Open a 6.0L file and do a compare with a 5.3L. There are a lot of differences. Treat it like any modified engine and start tuning!!
Old 05-23-2012, 01:35 AM
01ssreda4's Avatar
Gonna need a fresh tune. I installed a 5.3 with a 98 PCM and the setting stayed at 5.7L. The setting doesn't change the tune from what I've read, you will still need to work the stock tune over for the engine swap.
Old 05-23-2012, 07:19 PM
ok, thanks I ws hoping it was as easy as changing the engine type for cylinder air. It has a box with different size engines to chose from. Well here go nothing!
Old 05-23-2012, 07:38 PM
Moderator
jimmyblue's Avatar
You do need to change the cylinder volume for starters.
Old 05-23-2012, 07:40 PM
Lee12609's Avatar
back years ago i know the displacement box made fuel changes based on displacement, this could have been taken away with the many many updates and newer versions now.
change it and see if the VE tables change.
Old 05-23-2012, 09:45 PM
flame's Avatar
Do the compare, copy differences and make sure you set the injectors for what you are using and tune away.
Old 05-23-2012, 09:51 PM
Ok, I can save differences? Im really new to this, but im trying!
Old 05-24-2012, 05:14 PM
Did a compare, and theres nothing different! All of it is the same, so I hope it run as well as the 6.0 did.
Old 05-24-2012, 06:06 PM
flame's Avatar
They are not the same. Open the 6.0L file, open the 5.3L under compare, then view comparison log at the bottom of the list under compare. It will list all the diiferences. If you want to copy them over right click and copy over differences either one by one or by folder which ever you choose.
Old 05-26-2012, 12:04 AM
01ssreda4's Avatar
The stock tunes should definitely be different. However, all I was saying is by changing the drop down box for displacement should not effect that particular tune. Meaning changing the drop down box changes nothing else.
Quick Reply: Changing from 6.0 to 5.3, do I change it in HP?
