Dyno Guesses & Bench Racing Forum - How well will I hang with this Z?
DeLaRosa25
05-21-2012, 09:38 PM
Going to be lining up with a 2002 Z28 in town. Talked with him today from what he told me. Slp lid, Long tubes, catback, 4.10s, super chip, and is an auto..75k miles
My mods are in the sig and I am 3.23 gears auto, 103k
We will be going from a dig/roll.
I have a good chance on pulling away from him? Any strategies I should be in. Planned on leaving it in D and launching it with cutouts open
ramair 1
05-21-2012, 09:46 PM
Look like a good match up.If he spins alot with that gear set up he will be seen taillights.Goodluck!
Gunslinger09
05-22-2012, 10:37 AM
If he hooks he will put a car or two on you out of the hole. Same from a roll. That rear gear gives him the advantage on what looks to be two very evenly matched cars.
Roarin_8
05-22-2012, 02:05 PM
Don't know about that super chip though...........
MasterTomos
05-22-2012, 03:03 PM
Usually when people tell me their car is "chipped" it tells me that they have no idea what they're actually talking about...unless he has a duramax swap?
thunderstruck507
05-22-2012, 03:56 PM
Should be a good race. If he really only has a shit Super Chips programmer instead of a real tune you have great chances.
You have a bigger stock cam, better lid, better exhaust, UDP, and a real tune on your side. He has gears on his.
If neither car spins or weighs extremely different, I say he jumps you out of the hole but you come around him and pull on him the whole race. Roll races will depend on the MPH, you are going to have very different sweet spots for the autos.
DeLaRosa25
05-22-2012, 05:03 PM
From a roll most likely it will be from a 25, and a 15...
From a dig should I just launch it at 2800 rpm and give it WOT till the end?
s346k
05-23-2012, 09:49 AM
given those mods i think it could go either way. these cars vary so much in performance mod for mod in stock trim its ridiculous.
i think you'll keep up enough and start to pull back from a roll given the gears, he will run out of breath around 100. the dig should be all you, unless he is on a DR.
thunderstruck507
05-23-2012, 10:26 AM
With 4.10s a 25mph roll might put him at the bottom of 2nd...if so you would slaughter him since you would get a first gear downshift.
The 15 mph roll if he doesn't spin a crazy amount I bet he jumps out on you.
DeLaRosa25
05-24-2012, 08:53 PM
Gotcha..just bought the SSRA..so that should help me a tad
thunderstruck507
05-25-2012, 08:45 AM
That should help your top end.
Confidence is growing that even if he gets you out of the hole, you pass and pull on him. By multiple car lengths.
This is assuming you both have traction. That will be the biggest factor in this match up I think.
DeLaRosa25
05-25-2012, 05:10 PM
From, from what I know he is just running street tires..as will I..only difference between that. My tires are brand new in the rear and his are down to a good 4.32nds from roasting them non stop. But he wont run untill he gets a set of tires im sure
