General LSX Automobile Discussion - Just got a delphi 85mm for my 02 z28
flattusmaximus78
05-22-2012, 06:50 AM
Going to purchase the casper harness. Do I plug the iat sensor into the new harness and let it hang outside of the housing? There is no place for it to go. Other threads said you remove it from the lid. I figure I remove it, plug the lid, plug it in and zip tie it off?
25168491 part number
3 screw holes
http://i3.photobucket.com/albums/y51/Scatmanjohn/IMG_1764.jpg
http://i3.photobucket.com/albums/y51/Scatmanjohn/IMG_1763.jpg
Going to leave the scrunchy plastic conector on there to keep it easy, and probably get a rubber hose conncector for front side to go over the lip and on the outside of the lid. I have an slp lid if it matters.
Rare96LT1Formula
05-22-2012, 02:36 PM
What kind of power are you making right now? Unless you're in the 450+ range you stand to make next to nothing power wise with the 85mm maf. You're also going to need a tune....
Need more information.
thunderstruck507
05-22-2012, 03:00 PM
I'm not following you.
You buy a harness that plugs into the 85mm MAF and has split to accept the stock MAF plug and the stock IAT plug. You plug whatever hole the IAT sensor was in since you no longer need the IAT sensor.
http://i.ebayimg.com/t/5-WIRE-MAF-3-WIRE-HARNESS-ADAPTER-IAT-/06/!BQN9-j!!2k~$(KGrHgoH-EEEjlLlyOEvBJ3p8)Ptug~~_35.JPG
You tune the car for the 85mm MAF.
Do not hold your breathe for any gains.
95LTXZ28
05-22-2012, 06:27 PM
^^^ What he said, the IAT is no longer used or plugged in. The connector that once plugged into the IAT now plugs into the connector on that casper harness. This lets the IAT be read from the MAF instead of the IAT sensor.
flattusmaximus78
05-22-2012, 07:28 PM
You guys answered all my questions! I did by the connector from summit (casper). Waiting on it to arrive. I plant to make 400 plus na an im getting my new combo tuned next week.
oldmano2z
05-22-2012, 08:06 PM
please tell me more about the 85mm will my stock slp lid fit ? i'm not trying to jack your thread but you young guys teach me alot . is that the gm part #? how much may i ask? i'm getting ready to install 36lb injectors and am close to pulling 415 rwhp will this help it breath better in turn give it a little push in hp like 1or 2 hp? this shit reminds me when we used to build harleys it never stops! but there ain't nothing wrong with that! thanks ahead guys. the oldman......
95LTXZ28
05-22-2012, 08:09 PM
I was running the 85 mm Delphi maf with my slp air lid with no problem. It was connected with a silicone coupler which may come with the lid. I'm not sure as this setup was on my car when I purchased it.
flattusmaximus78
05-22-2012, 11:01 PM
I have an slp lid. The outter metal lip on the stock maf fits inside. Pretty sure this metal lip is a larger OD than the OD of the slp lid. I'll know on Friday when I get some time to mess with it. I know the metal part of the stock maf with the lip inside the lid would not come off the lid. When i switched stock mafs I had to swap center sections.
Probably run a coupler over the maf and over the lid and secure it with two worm clams. If I don't have any more couplers I will try to clamp the scrunchy connector on the back.
oldmano2z
05-23-2012, 05:58 AM
see i have grey moments sometimes ,of course the coupling duh. is this just a better unit besides being bigger ? a more precision tune? i went thru mid am corvette and bought a screen eliminator kit,and currently run this but i keep throwing a po430 code and am wondering if maf is going bad so while i'm at it with the injector swap add anew maf?? hte car was tuned with the descreen. this p0430 code is hapening with more frequency and i just keep clearing it just put new o2 sensor in the mix still throwing codes thats why the intrest in the maf ... the oldman.........
flattusmaximus78
05-23-2012, 07:03 AM
Im gettin my hc combo tuned. Still had the stock maf, tb, and intake. I had a nitrous backfire and my stock maf was bad. Just buying this for down the road expansion. No maf is too big anyways.
loudblack97z71
05-23-2012, 08:05 AM
"no maf is too big" I'd have to disagree with this. For example: using a 102mm MAF on a stock engine would result in low intake velocity thus making the MAF readings inaccurate and difficult to tune, thus losing power. Do a search, people who put larger MAF's (especially aftermarket one's) on engines that dont pull enough intake velocity have tuning problems. Removing the screen has been known to create problems at low-rpm also because the screen is there to smooth out the airflow.
That being said, you should be fine with that delphi 85mm on your engine.
flattusmaximus78
05-23-2012, 11:27 AM
Why does it make a logged readin innacurate?
oldmano2z
05-23-2012, 08:42 PM
the photo of the 85mm has no screen what about the airflow pattern? is it straight? flattusmaximus what is the casper part # for that pigtail you're getting if so kind to let me know. i 'll get my engine tweeked and then listen to my rearend whine it's getting so loud that my ac/dc can't cover the noise, sounds like a turbo spooling up i think it's gonna leave me along the highway soon.anyway i have a stock ls6 with arh headers and gmmg cat back . i would have enough of an engine for the 85mm to be of benefit? the oldman.........
flattusmaximus78
05-24-2012, 03:35 PM
First off... ACDC ftw. Seen them 3 times. Best band ever and current. CAS108100 is the part number I beleive. I doubt it will add power if that is what you are looking for. In the ford world a huge maf never messed with the ability to tune my car. I just needed a new maf and I fiugred this would be good for down the road. I don't see any real negatives.
oldmano2z
05-24-2012, 08:42 PM
i saw them twice oakland 78' days on the green with aerosmith and ted nugent thats when bon scott was alive ,then in80' in nueremburg with bryan johnson the back in black tour.i'll give the 85mm a shot like you say it is there to build on with my 36lb injectors it should keep me close to 80% duty cycle that should also be room to grow with a cam. i still have my original ls1 with 70k on it that when the economy picks up i want to make a square motor i think it's a 388ci .. the oldman.........
flattusmaximus78
05-25-2012, 04:29 PM
I would do bad things to see Bon Scott between Powerage and Highway to hell. Same goes for Brian on the back in black tour!
:hail:
Either way. The 85mm fit on the stock coupler from the maf to the tb. I put a 4x4" coupler on the lid to the maf and used two slightly larger tbolt clamps to tighten it all done. The coupler covers up the hole from the iat.
http://i3.photobucket.com/albums/y51/Scatmanjohn/IMG_1777.jpg
http://i3.photobucket.com/albums/y51/Scatmanjohn/IMG_1776.jpg
oldmano2z
05-25-2012, 10:06 PM
flattusmaximus78, where did you get coupling and 't'clamps rather limited around here,also that is a delphi part#? and the casper a summit #?? thanks a picture is worth a thousand words. i should take the time to learn to post pics. oh by the way i also saw led zep in 80' twice in 8 days on one ticket once in nuremberg and once in munich awsome!! had a 100lb german chic on my shoulders! "it's better to be old and cool than to be old and uncool!" the oldman.........
flattusmaximus78
05-26-2012, 05:02 PM
'That was the part number from my maf. If you type in ls1 casper harness on google the harness will show up with a link too summit. Shipped in 2 days. Only negative was you have to ziptie the wires up. They are longgggg!
The coupler was from my job and so were the tbolt clamps. They just happen to be a perfect fit lol. A 4 inch by 4 inch. Sounds like to you didn't miss any shows dude haha.
Car fires right up afterwards. Not driving it since it's a h/c car and I installed fresh plugs after, don't want to follow them out.
flattusmaximus78
05-27-2012, 12:18 AM
Foul*
oldmano2z
05-29-2012, 05:47 AM
explain:foul*???
flattusmaximus78
05-29-2012, 06:02 AM
My car is untuned and I just did a h/c. When It was running very rich before, but now I swapped some 34lbers in. So after letting the car idle once, the plugs will foul out and it wont idle.
BOBS99SS
05-29-2012, 07:40 AM
Nice upgrade, this is something i need, i think its a pointless mod for a mild car though, just dont want someone with a bolt on car thinking this will do something for them
Cwarta
05-29-2012, 08:13 AM
I just installed an 85mm Delphi on my 04 ls1 gto. If you dont have your car retuned, its going to run stupid rich, surge on the highway etc. You will guranteed LOSE performance if you dont have it retuned immediatly.
oldmano2z
05-29-2012, 07:43 PM
flattus, my tuner told me to wait and put the injectors in at his shop.you might want to wait to get to the tuner before the addition of your maf and injectors. i'm not telling you what to do because i'm not well versed in the modern stuff. what i'm gonna do is mock up with 85mm and have my injectors ready.your motor looks all business wish you great sucess. changing those fouled plugs will get old fast... the oldman......
flattusmaximus78
05-29-2012, 09:01 PM
Nice upgrade, this is something i need, i think its a pointless mod for a mild car though, just dont want someone with a bolt on car thinking this will do something for themI don't see it messing with something, but for the deal I got on this, it will be perfect for my combo!
I just installed an 85mm Delphi on my 04 ls1 gto. If you dont have your car retuned, its going to run stupid rich, surge on the highway etc. You will guranteed LOSE performance if you dont have it retuned immediatly.Good to know, but I'm glad I'm not driving mine haha.
Agree! Good lookin' out. I haven't even left the driveway with this combo! The guy that put it together for me drove it around the block after the first start up, but that was about it. We found out I had a bad maf and I towed it back here and it has sat in my driveway since april. I was waiting to do an 8.8 with 35 splines and a spool, but it was going to take forever to have the time to get it together. So I will be getting tuned with 3.27s for now. The trans is built and so are well, other things ;).
I put the injectors and maf on the other day only because she is getting towed to the shop. I had to take my diable predator tune off the car too so I did the maf and injectors first, made sure it ran, then did the tune to make sure she was fine, and all is good! I def would not drive up there with these. My stock plugs would foul out after idling for 20 seconds in the driveway because it would never get moved. You should be fine man. I am estatic to finally get tuned.
oldmano2z
05-31-2012, 05:36 PM
got my 85mm today and it has a screen in it. wheither or not it's a performance mod in my opinion it's an upgrade from the old style in order to fine tune the air/fuel mix is that correct? regardless it lets more air in correct? goes back to the question : screen or descreen? i'm not worried about debris. flattusmaximus, i saw yours is desceened? explain you said nitrous backfire? i still look at the screen in a different way if you took the screen and compressed it it would turn to a solid mass and the material if combined to be a solid not asceen that is the amount of obstruction in the intake tract . am i reading into this too deep?? the oldman...........
thunderstruck507
06-01-2012, 08:10 AM
leave the screen in or replace it with a better one:
http://ls1tech.com/forums/generation-iii-external-engine/1413807-replacement-air-flow-straighteners.html
oldmano2z
06-02-2012, 09:15 PM
thunderstruck507, flatusmaximus, and all others for the knowledge on helping me with everything. the hp tuners stuff was interesting and i will leave the screen on the new maf seems to make it more efficient by the tuner guide and graffs thank you once again the oldman.....
