Generation IV Internal Engine - What options do I have for LS3 rockers
fc3slsxpwr
05-22-2012, 03:24 PM
Hey guys. I am running a 429 ls3 stroker using the SDPC cncd ls3 heads. My cam has .620 lift with a 1.7 ratio rocker. I would like a roller tip 1.8 rocker if possible. I do road race the car. I run the engine up to 7000rpm. The car is a 2600lbs RX7.
What are your thoughts and experience.
I like the new comp ultra pros. But it seems like they will never be in production.
Thanks,
Ryan
AES Racing
05-22-2012, 04:40 PM
Experience has proven that Yella Terras operate the best in your application.
Gray86hatch
05-22-2012, 04:49 PM
Design the cam for the rockers being used. puting a 1.8 rocker on a cam designed for 1.7 is not the prefered way.
Stock rockers with a trunion will do what you are asking
Tim
bww3588
05-23-2012, 02:20 AM
Road racing, I would look for a full roller. Of course tim is right sticking with the 1.7 ratio.
However you will need a very good rocker to have good balance. The cheaper rockers (less than 1k) seem to have some issues with excessive nose weight causing instability and failures.
fc3slsxpwr
05-23-2012, 02:46 AM
I have stock rockers with the comp trunion upgrade right now. I am just curious if the none roller tip causes crazy heat and side load on the valve. The engine does see a lot of rpms. I just want to make sure I have a very reliable setup.
93-Z07
05-23-2012, 05:26 AM
On a side note, how are you liking your SDPC heads? They're my number one choice right now just wondering what your experience is with them. :burn:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
