1982 ford fairmont
1982 ford fairmont
trunk
http://www.youtube.com/watch?v=rN4zMvrYI0o
im sorry i forgot details...
2001 silverado 4.8l, ls1 intake, zr1cam, pac1218 springs, arp bolts stock HG's
th400, 3500stall with b-plate, hurst 1/4 stick shifter.
MSD6010, MS1 built and installed and tuned by me.
16g fuel cell, jayracing 044 fuel pump -6feed -6return
g8gt manifolds, home made turbo kit, gt45 turbo, x02 60mm wg, aem tru boost controller.
91 mustang 8.8, welded stock diff, 28 spline alloy usa axels, 2.73 gears.
i had a 1350 driveshaft built with a 80e yolk i cut out of a truck and a explorer *** end
it makes 513rwhp on low boost 14psi. i have a trunk mounted methanol kit that comes on at 10psi, i run 20lbs high boost right now.
i had a loose rocker when i made that 640pull, might be making more now.
thats my best stuff to date, i only have like 10 passes setting up the boost controller and realizing 2.73 gears, 3000 stall, and 27 inch tires does not = launch master, thats why the juice is there. gunna up the jetting and try a fresh pair of radials and see if i can get a 1.6
