New LS1 Owners - Newbie Tech - Need help with cam and stall size..
Thrdlife
05-23-2012, 12:18 AM
I can't decide what cam and stall size to go with.. The car isn't my DD so drivability isn't a big deal. I wanna go cam only. I researched for days and many of the previously asked questions aren't the same as mine. I want peak power between 5800-6300 so I don't over rev the 4l60e. I was thinking a 228r cam with a 4000revmax stall. My main goal is to have a cam/stall setup that will work really well on the street and smoke some SVT COBRAS along the way.. I was looking at an ms4 cam but That would require revving up to 7000krpm just to get peak power..
TyCZ28
05-23-2012, 12:33 AM
try a torquer v2 with a yank or vigilante 3800 stall. torquer has a nice powerband and shouldnt over rev the motor if you get maybe a 113 or 114 LSA
thatoneguybriz
05-23-2012, 12:42 AM
Check out the TRuTorq Level 2 by Thunder racing, John at their tech line was steering me that direction and it sounds like you and I have similar goals.
Thrdlife
05-23-2012, 01:05 AM
I've been looking at the torquer v2 but idk if it's right for me... maybe a donkey dick cam like an ms4 with a low lsa like 110
Thrdlife
05-23-2012, 01:11 AM
I guess my real question is that I need help finding a well layed out mild cam like a 228r and a stall that will work very well together on the street and not a monster that will blow the tires off and need 7k rpm's to do anything.
99Bluz28
05-23-2012, 01:58 AM
IMO, just get the TSP 228r with a 111lsa.
Also a 3600 stall would be plenty big with this cam.
mjs1012
05-23-2012, 07:03 AM
The 228r w/ a 3600 stall is a very drivable set up
udienow
05-23-2012, 08:16 AM
Wouldnt he want more then a 3600 stall? I know people who daily drive 3600 stalls and wish they had got bigger stalls.
RPM WS6
05-23-2012, 10:14 AM
I would do a TSP 224 on a 112 (or 114 for a little easier tuning, though it will raise the power band a bit) and a 3600 stall. That should keep your peak at or near 6300 and make great torque throughout the useable rpm range.
Thrdlife
05-23-2012, 12:03 PM
thanks guys i'm pretty settled on a 228r either a 111 lsa or 112 lsa.. What would be the best performing stall on the street for that cam.. 3600 or 4000 or even maybe in between with a 3800.
BigBirdLS1
05-23-2012, 12:49 PM
RPM hit it right on the head a 224R on a 112lsa is what cam I have and it peaks 6100rpm. It loses 7rwhp and 4rwtq to rev limiter at 6500. My car is a 6spd though vs. your auto. Either way you can't go wrong with a 224r/228r and 3600 stall. Great street manners and will be a blast on the street.
TyCZ28
05-23-2012, 04:32 PM
you dont want a 110 LSA... lower LSA is going to make it get its peak power higher. (Higher RPM)
99Bluz28
05-23-2012, 04:43 PM
Sorry but that's wrong! :nono:
It's a higher lsa that will put the peak power higher, that's why I'd suggest a 111 or even a 110 lsa..
RPM WS6
05-23-2012, 04:44 PM
Depending on your head/intake setup, this cam may be a bit too big to be ideal for your 6300rpm shift point that you mentioned above.
The 4000 stall would be better for performance, but traction will certainly be more difficult. I would probably stick with the 3600 for a street only car, but neither one would be a bad choice.
:nod:
It's the other way around. Lower (numeric) LSA numbers will make peak power at lower rpms than the exact same cam on a higher number LSA (all else being equal).
99Bluz28
05-23-2012, 04:58 PM
Example:
FYI, a 228/228 110lsa +3, and a 224/224 112lsa +3 should make peak power at the same rpm.
That why I suggested a 3600 stall and not a 4000.
Also if later you decide you want your cam to peak a few hundred rpm higher then you can just retard the cam those 3 degrees.
RPM WS6
05-23-2012, 07:13 PM
Example:
228/110lsa will sacrifice some street manners and idle quality in an A4, versus the 224/112.
Even a stock internal LS1 will run better times with a 4000 stall vs. a 3600, assuming full traction is possibile. But which is "better" overall for a given setup is a matter of driver preference and how much tire you plan to run. There is no question that a 4000 stall (of equal build quality and similar STR) will have better ET potential with the right tires/suspension behind even a stock internal LS1 (and most certainly with a 224-228 cam).
garygnu
05-23-2012, 07:39 PM
check the auto trans section for converter sponsors and talk to them.after you get the converter get the cam.the more radical the cam the more it cost.with a more wild cam you need dual springs and some comp trunnion bearings.call thunder racing or TSP and tell them what you want.Damian has a nice cam he uses on fast street cars.
TyCZ28
05-23-2012, 11:50 PM
Then why do turbo cars need a higher LSA? i thought it was so that they had power when not in boost??
99Bluz28
05-24-2012, 02:03 AM
Well it's all a compromise, if he goes "cam only" with a 224r 112lsa he'll be wishing he went bigger. Furthermore the 228 with 110lsa was just given as an example, but I would still recommend a 111 or 112lsa with the 228/228 cam since he would like to make peak power by 6300rpm. The 3600 stall would still work really good with a 228, and I didn't say it would get him the fastest track time only that it was a good option beside 4k stall.
Thrdlife, update us once it's all said and done.
14k
05-26-2012, 11:51 PM
I'm in the same boat. Decided on 228r now stall choice... I'm thinking 3200 or 3400
GMtechmatt
05-27-2012, 10:50 AM
if your looking for a good stall try R&R converters out of ashville NC very good tell them matt sent you!
