first start after heads and cam
i just put some 799 heads and a 610 lift cam in my car and got to start it last night for the first time. it seemed to run great off idle and sounds 100 times better now but it wont idle at all. i have herd you have to drill out the hole in your throttle body, if so how big?
i just put some 799 heads and a 10 lift cam in my car and got to start it last night for the first time. it seemed to run great off idle and sounds 100 times better now but it wont idle at all. i have herd you have to drill out the hole in your throttle body, if so how big?
You could try this post no.6 might get you a little idle till you get it tuned.https://ls1tech.com/forums/pcm-diagn...-idle-ls1.html
