Drag Racing Tech - What causes fish doing
babygirl02
05-23-2012, 11:20 AM
When I went to the track my car started swaying shortly after launch got it under control then it jotted out to the right and I smashed into the guard rail what are the potential causes for this
Z28/2002
05-23-2012, 11:40 AM
need more info on the setup
AChotrod
05-23-2012, 01:21 PM
Broken TA could cause that. Seen it happen before.
Fbodyjunkie06
05-23-2012, 06:45 PM
Too much powa?
Because race car?
Doug G
05-23-2012, 08:01 PM
Water/oil/anti-freeze on track under one wheel ?
Old Geezer
05-24-2012, 06:19 AM
14 sec driver in a 10 sec car??
As mentioned, how about some info...............
ramairetransam
05-24-2012, 07:16 AM
a woman driver mod
fex77k
05-24-2012, 11:24 AM
If there is fluid on the track it will send you into a rail.
armyboyatc
05-25-2012, 04:27 PM
Too much powa?
Because race car?
LMAO we say that down here man. Shit trips me out.
tektrans
05-25-2012, 05:07 PM
All good responses but w/o more info I'd chalk it up to inexperience.
Lined up outta the groove, spun a little-car got outta shape, you straightened it out for a second, or so you thought-punched the throttle-tires bit the sticky track but chassis was upset and sent you into the wall.
It's not like getting it sideways on the street and spinning it straight-once the tires bite the sticky track surface the car better be straight, weight transferred efficienty, stable and not upset. If she bites, she's bites and there's not much room for error.
If you sway-get out of the throttle and coast thru-figure out what went wrong then try again the next pass.
babygirl02
07-30-2012, 04:25 PM
thank you all for your replies turns there was fluid on the track and a rear end issue
subhumanzz
07-30-2012, 04:59 PM
Love the title. I was wondering wtf I was in for when I clicked it.
wws699
07-30-2012, 08:18 PM
what tires? Specs on front and rears
98z-28redcamaro
07-30-2012, 08:57 PM
im sticking to "because racecar!!!"
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
