Cadillac CTS-V - Please help Oil pressure dropping??
CTSVer bullet
05-23-2012, 07:55 PM
Hey guys i just bought a 2005 cts-v and ive had it for about 2 weeks now and just today i was slowing down to a stop light and the oil pressure low light came on and told me to shut down. the car has a mp112 superchrger on it also. It only seems to drop when the rpms are low any help would be great.
RRsV
05-23-2012, 07:58 PM
Get rid of that POS now before its too late! You can thank me later...
Skidmarcx
05-23-2012, 08:03 PM
^^ Lol that's some funny shit... How's your oil level? Lots of considerations with the blower on the car.
ichpen
05-24-2012, 07:46 AM
Does it go to 0 or max quickly like it glitched? There's a whole article on oil pressure senders that go bad on our cars fairly frequently. More than likely it might be it.
STAGEUP
05-24-2012, 09:44 AM
Could be lots of things. One being a bad sensor. Another could be a weak oil pump, and the worst being a bad rod or journal bearing.
TheLostDriver
05-24-2012, 10:23 AM
Sounds like spun bearing. Check oil level. If the level is good, drain your oil and check for metal shavings.
CTSVer bullet
05-24-2012, 11:22 AM
the oil pressure sending unit is bad i had it checked last night.
The shop is sayin that they may need to remove the charger to replace it though??
And are we talking about the charger here? lol whats so bad about this one?
DMM
05-24-2012, 11:54 AM
The Maggie comes with a new valley cover that you have to change out since it's flat and has the recessed area's for the O-rings for the supercharger to sit on. If the installer didn't pay attention when installing this plate, they would not have seen the plate touching the oil sending unit so that you cannot get a socket on it.
If this is the case, they will have to remove the supercharger and the valley plate to grind the back corner so that you can get to the sending unit again. The thing that really sucks is that the valley cover bolts get seized to the cover and at least one will strip out (they are internal hex).
If the original installer took the time to grind the valley cover before installing it, its literally a five minute job with the "special" socket.
heavymetals
05-24-2012, 12:20 PM
Don't remove the S/C to replace the oil sender.
You can remove the windshield washer unit and fascia and get at the unit.
Also, if you have to you can Dremel the flange if it interferes with the sender.
I have replaced three or more (I pop these things like fucking corn) and now I can do it by "feel" and I don't remove anything to get at it.
CTSVer bullet
05-24-2012, 12:32 PM
Awesome, that was the last thing i wanted to do was take the charger off im glad there is another way.
Thank you for all the help i surely apperciate it.
heavymetals
05-24-2012, 01:07 PM
You can get a thinwall socket wrench specifically made for sensor removal from PEP Boys, or Autozone or Amazon
http://www.amazon.com/Lisle-13150-Pressure-Sending-Socket/dp/B0002SR2V0/ref=sr_1_2?ie=UTF8&qid=1337882702&sr=8-2
