Cadillac CTS-V - I hate to even ask this, but I have a tire question I need some quick help with
UnsafeAtAnySpd
05-23-2012, 09:58 PM
As the title says I hate to ask a question that's been asked many times before I'm sure, but I can't find specific info. I just found out today that it looks like I'm going to have to go to Alabama for two months for training. I've been meaning to pick up some new tires and need to do it quick now.
I was looking at 285/35/18s and 255/40/18s on Team Dynamics wheels (18x9).
I don't forsee any rubbing issues or anything, but most with the 285s don't seem to be running TDs.
I currently use the TDs with Hoosier R6s with 275/35/18s all around and they work fine on the track.
I'm looking at the Hankook Ventus V12 evo as a set of 4 only runs $700 plus shipping (I miss the last set of summer tires I bought for $400 shipped).
Any thoughts? Thanks.
NeverSatisfied02
05-24-2012, 12:22 AM
Hankook makes a good tire for the money. I'd run either those or the Nitto 555's if you're looking for a good tire for the money. Both have a good looking tread pattern and perform well for the money.
You'll be fine with the 285/35's and 255/40 combo. I prefer the staggered look myself so thats what i would do. Its just a little shorter both front and rear than the factory overall diameter of the 245/45/18.
SSmokd U
05-24-2012, 07:46 AM
I'm glad you asked this question cause I was wondering if 255/40 would fit the front good. I've got some 265/35 I am putting on the rear.
den_99_GTX
05-24-2012, 10:06 AM
I have 255/40/18 on the front and 295/35/18 on the rear. Diameters are very close to each other.
NeverSatisfied02
05-24-2012, 10:55 AM
I had 255/40 and 295/35 on my old V. Looks nice. I have 255/40 and 275/40 on this one right now. 255/40 fits just fine up front.
Ssmokd... I wouldn't run a 265/35 out back with the 255/40 up front. The 255 will be taller than the rear.
Google "tire calculator" and discount tire has a calculator that u can put in ur sizes and compare overall diameters, widths, sidewall height, etc. That will help u keep the tires the same height front and rear.
SSmokd U
05-24-2012, 11:00 AM
Dammit. That's what I was afraid of.
RandallBlackwell
05-24-2012, 11:23 AM
Hankook V12 evo 285/35/18
SIZE 285/35ZR18XL
UTQGL 280 AA A
SERVICE 101Y
SUPPLIER 1008657
MIN RIM WIDTH 9.5000
MAX RIM WIDTH 11.0000
OUTER DIAMETER 25.86
Single Max Load lbs 1819@50
Dual Max Load lbs NA
RPM 803
TREAD DEPTH 10.00
SHIP WEIGHT 28.330
Hankook V12 evo 255/40/18
SIZE 255/40ZR18XL
UTQGL 280 AA A
SERVICE 99Y
SUPPLIER 1008658
MIN RIM WIDTH 8.5000
MAX RIM WIDTH 10.0000
OUTER DIAMETER 26.04
Single Max Load lbs 1709@50
RPM 798
TREAD DEPTH 10.00
SHIP WEIGHT 26.290
these are my specs through ATD
NeverSatisfied02
05-24-2012, 11:58 AM
Its not a big deal for you guys to go a little shorter both front and rear. A lot of people do. With my 4.10 in the rear, im sticking with the factory size OD in the rear.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
