Stereo & Electronics - Power Antenna Wire diagram
View Full Version : Power Antenna Wire diagram
Daniel Richards
05-24-2012, 07:24 PM
OK so this past weekend I tackled the job of getting my broken power antenna to go down (it was jambed in the up position) and I noticed the power plug for it has 3 wires, I'm assuming power, ground and remote, am I wrong?
If so what I would like to do is take advantage of that wiring as its the proper gauge to run my Epicenter (my plan is to hide it back there mounting to one of the screw points on the antenna base), I have NO plan to ever use an antenna in that location again, so what I need is a wiring diagram for the power antenna 3-wire plug for a 99 firebird NON-monsoon.
Thanks.
tsench
05-24-2012, 09:14 PM
here ya go
http://desmond.imageshack.us/Himg600/scaled.php?server=600&filename=22236248.jpg&res=landing
Daniel Richards
05-24-2012, 11:34 PM
thanks thats exactly what I needed, so my idea should work since if I'm reading that right all the relays are in the antenna base/motor assembly.
WhiteBird00
05-25-2012, 07:05 AM
This has been discussed several times before (search is your friend). You have three wires... orange, pink, and black. Orange has constant (battery) power, pink has power whenever the head unit is powered on, black is ground. The pink wire will work differently with some models of aftermarket head units - some of them lower the antenna (shut off power to the pink wire) when using an audio source other than AM/FM radio (e.g. CD or USB).
Daniel Richards
05-25-2012, 12:59 PM
Yeah I found one post that listed the colors after I created this thread, I have a Pioneer HU with just the one remote wire, My connection behind the headunit will be remote wire out of headunit to both stock "power antenna" and my existing remote to my amp, the purpose of all of this is to get the epicenter off of the rigged "ghetto" jumper wires from the amps power, ground and remote (I don't have a distribution block) and the power antenna wires are the proper gauge for the epicenter, now I just need to get a set of RCA's long enough to reach all the way back there.
Daniel Richards
06-11-2012, 07:53 PM
Got some nice new (and long enough) RCA cables cables coming so I can finally do this, would of had them today but some Postal worker in Atlanta put the package on a truck to Aiken, SC, then some other Postal worker loaded it onto a delivery vehicle in Aiken, SC before someone realized it wasn't supposed to leave GA.
