Timpala62
05-24-2012, 08:32 PM
I have LS2/4L70 swap. speartech harness with ecm programmed for Cruise control with blue, lt blue , gray wires from harness....also ididit column with their Rostra signal lever CC. Anyone done this install? I cant get it to work? any ideas? followed ididit diagram still not working.......TIA
garys 68
05-25-2012, 06:44 AM
You'll have to see if the switch is set up for the ford or GM switching. GM closes when the "set" button is pushed. Fords the opposite. When I got mine from Dakota Digital, the only stalk controls were ford style. They did make a dash mounted unit for GM.
http://ls1tech.com/forums/conversions-hybrids/1365002-dbw-cruise-control-lever.html
