Pontiac GTO 2004-2006 - new setup
View Full Version : new setup
2004yjgto
05-24-2012, 10:11 PM
I never have posted pics on here of my current car or my last one but I'm getting excited about this GTO(been apart for 9 months)
http://i623.photobucket.com/albums/tt315/leighannandmike/newsetup.jpg
at pinks all out
http://i623.photobucket.com/albums/tt315/leighannandmike/PINKS2001.jpg
I just dropped in a new engine
12.2:1 383c.i. Small bore LSx
4.8/5.3 truck block machined by Jerry's Motor and Machine in El Reno, OK
Wiseco 3.903 forged nitrous pistons -2cc valvie reliefs
Wiseco ring pack with steel top and napier second. Gapped LARGE x HUGE for nitrous
Callies 6.125 rods
Callies 4" crank
Clevite main, rod, and cam bearings
Texas Speed ported oil pump
Rollmaster double-roller adjustable timing set
LS7 hydraulic roller lifters
Custom COMP Cams cam ground for nitrous
Factory roller rockers with COMP trunion upgrade
COMP magnum 7.425 pushrods
PRC 227cc cylinder heads with 61cc chamber and PRC .675 lift springs
COMETIC .040 head gaskets
ARP main studs
ARP head studs
ARP 2000 rod bolts
thinking it may run pretty good
custom wheels ok not custom just powder coated factory 17's rears wrapped with Hoosier drag radials 275/40 17
joeyagls1
05-25-2012, 07:55 AM
thats real nice set up with the lines and direct port. I am going to get my direct port done few weeks from Nitrious Outlet though. Wish you luck with it!!
ACCLR8N
05-25-2012, 11:22 AM
Looks like you are serious. Should run good. What have you done to the back end?
6PntHo
05-25-2012, 09:01 PM
awesome build man, i love the direct port. is she a 6 speed?
mark21742
05-26-2012, 06:41 AM
You'll be luck if you don't blow the welfare on your intake and loose that peice of diamond plate you have bolted on the passenger floor the first time you run it lol
No, but seriously man you have got a sick sweet set up there!
2004yjgto
05-26-2012, 08:52 AM
thanks guys
she's an A4 built to handle 1000rwhp followed by DSS one piece aluminum drive shaft, BMR axles all built to handle 1000 rwhp also I have the 5/16 raised rear drag springs from Pedders.
best n/a 60' last night was 1.835 I need to learn to tune this thing myself so I can tweek it at the track.
6PntHo
05-26-2012, 12:00 PM
thanks guys
thats awesome, i need to upgrade to a few parts like that.
2004yjgto
05-27-2012, 01:45 PM
Every GTO should be over 500 rwhp lol
thehazz12
05-27-2012, 03:57 PM
What heads are on that thing? You've got some serious compression there.
mark21742
05-27-2012, 04:36 PM
What converter are you running? I've lost a few very well built a4's because of the converter clutch going out, then taking out the front pump....then you know what happens lol.
2004yjgto
05-28-2012, 07:41 AM
It's a vigilante 3600 stall
Heads are PRC stage 2.5
2004yjgto
06-01-2012, 11:22 PM
well I went and ran my car tonight for the first time on the new setup and lost overdrive on the way home.
what do you guys think about a turbo 400/350 swap
impulsegoat
06-02-2012, 12:25 AM
Yup, found out first hand when my 3400 ptc spit shavings into my 60e. I now have a Vigilante 4000 stall in it. The converter already feels night and day better than the ptc i had before. Can't wait to get to the track with it.
impulsegoat
06-02-2012, 12:44 AM
Did you make any passes before the trans started to give out? The most popular swap seems to be the 4l80e. You could also just have your 4l60e sent in and built. Btw your car is sick!
2004yjgto
06-02-2012, 06:55 AM
yes made three passes 1st spun full 1/8 mile well chirpping tires for the big end half
second I ran a 4 eyed stang on the bottle to my motor spun for about 75' then drug his ass
third run was a motor pass also against a supercharged nitrous fed silverado with my wife driving my car. I should of turned the bottle on for her.
Thanks for the compliment man the old car is fun to drive when it's not shitting parts
GTOSE
06-02-2012, 01:31 PM
Sick YJ!
Post up some video's of a pass when it's all together.
2004yjgto
06-02-2012, 03:06 PM
I wish I had a gopro!!!
the guy that was videoing everything is all butt hurt because I sold someone parts that he said "I want but I'll get with you sometime" and another guy said "I want the entire package today!! will you take cash??"
needles to say I took the cash that day. and I won't get video from him anymore
6PntHo
06-02-2012, 03:16 PM
sorry bout your trans issues..
fuck yea!!!!:headbang:
mark21742
06-02-2012, 03:34 PM
I know several people that have done the th400 swap in their f-bodies, and if I ever go auto ageing that is the way I would do it....but after 4 tranny swaps in mine (dead 4l60s) I swapped to a good old 3 speed Saginaw manual :)
2004yjgto
06-02-2012, 09:34 PM
I guess I need to contact Chris at g-force and talk with him on the swap
mark21742
06-03-2012, 12:16 AM
I looked into it and It's pretty strait forward. You can either get a spacer and flywheel, or an adapted torque converter that bolts right to the ls1 flywheel and slides right into the th400 or th350... You will need a driveshaft, and tranny mount adapter also, but for the most part very easy swap and the motors have the same bell bolt pattern.
2004yjgto
06-03-2012, 09:22 AM
Mark Ty very much for the info. Who makes a good torque converter. I have a vigilante now. I have only ever had one stall converter and that was a B&M
