Corvette Performance - headlights are grinding.. how can I fix this? please help
rio95cobra
05-24-2012, 10:56 PM
the pop up lights in my c5 go up and go down fast and smoothly.. except when I turn the headlights off and the lights go down, I continue to hear a loud grinding noise for around4-5 seconds.
do I need to replace the gears? or what can I do to make it stop?
slammedc5
05-25-2012, 12:01 AM
Yeah, just did mine. Had the same issue as you. I upgraded to the brass gears.
rio95cobra
05-25-2012, 05:58 AM
But the gears are obviously turning and working fine because the headlights still go up and down. Could it be something else?
slammedc5
05-25-2012, 01:11 PM
There stripping when there making that noise, won't be long before they won't open or close. Your at the " your being warned" phase.
http://www.vetteweb.com/tech/vemp_0406_c5light_gearing_up/viewall.html
GTSC5R
06-07-2012, 04:38 AM
Gears are stripped, you can replace with brass gear and never have a problem. I went with the free route and spun the gear to an unused portion and never had any problems for years. I can't find the link for the how to, but you might want to check the corvette forum, this site is pretty lite on vette specific stuff.
chuck01
06-07-2012, 04:39 PM
He is correct, just do a search on the corvette forum. You can buy a plastic gear and fix it on your own for less than $15 Bucks.....
Silver408z
06-07-2012, 05:08 PM
Its your gears. I had same problem and thoughts when it happened to me. I replaced it and havent had the problem since
