Limp mode? Car ignores me going down the highway!
What the heck is going on!!? I have a '69 with a brand new LS6 with a magnacharger.. I have about 500 flawless miles on it this spring.. HOWEVER, two of the last three trips - i've had an issue that I cannot figure out..? Just driving down the highway at 75mph, the car will become completely unresponsive like it's in a limp mode or so to speak? The engine will lose RPM's, the car slows and it's like on cruise control at 1400RPM (which is not hooked up at the moment). The engine stays running, I just cannot accelerate. The Electronic gas pedal becomes completely unresponsive? I can push the pedal to the floor, but the engine does not respond. All the gauges read good - oil pressure, temp, etc. Both times I've been able to correct the issue by turning off the ignition, waiting 5-10 seconds, and then re-starting the car (while coasting down the highway) and it will take right off like nothing ever happened? I threw my handheld decoder on the computer and the only code it is throwing, is the vehicle speed sensor, which is not hooked up. Any ideas what could be causing this? I'm planning on attending the Hot Rod Power Tour in a couple weeks and Im getting nervous about the reliability!!! Appreciate any help.
Thanks, Jason
Thanks, Jason
I checked the connection at the TB.. I will check the other wiring and connections tonight.. I did put the scan tool on after the first episode and it didnt show any errors at the time (other than VSS, which I do not have). Of course, that was after I turned the car off and back on and it was operating normally.. Thanks for the reply.
We'll I wish I could say I found the definitive problem, but I didnt... I took apart every connection, blew them out, looked at the terminals, sprayed contact cleaner, etc. hooked everything back up.. I even inspected the TB blade and sprayed it with some cleaner and light coat of Wd on the rod.. Put it all back together and knock on wood, but I've put almost 800 miles with NO episodes.. I even ran almost 500 miles in one day on the Hot Rod Power Tour - flawless.. I think it must have been terminal/ connection related - but so far, so good.. Thanks for checking in.. Jason
