Generation IV Internal Engine - Lightest Titanium retainer for Beehives?
Charles Cyrus
05-25-2012, 07:06 AM
Who makes the lightest titanium retainers for PAC-1518 valve springs?
Thanks
TurboBuick6
05-25-2012, 09:00 AM
Ours are 5.7g each. Not sure if you are going to find a lighter one.
427 zeo6
05-25-2012, 03:38 PM
Comp Cams tool steel retainers are 2 grams heavier than their Ti stuff. For cost and strength, I don't think you can beat them.
Haans249
05-31-2012, 11:21 AM
2 grams could make a big difference in valve train stability. The lightest possible would be best.
to Original Poster: The setup i have used in the past:
PSI-1511ML springs and Katech retainers = .700 lift capable on LS7 heads, retainers weigh ~5grams, lightest valve spring setup around.
Charles Cyrus
06-02-2012, 10:52 AM
This is what I've found on the internet.
Stock steel retainers------------10.1 grams
Comp cams Titanium retainers----7.2 grams
PAC Titanium retainers-----------5.7 grams
Katech Titanium retainers--------5.2 grams
PSI-1511ML Beehive springs------65 grams
PAC 1518 Beehive springs---------62 grams
Thanks Guys!
3rdCoastPowerSports
06-04-2012, 01:38 PM
Thanks Guys!
I was just looking for this info... Thank you for posting up what you found, made my day easier.
dhouston02
07-18-2012, 11:47 AM
Thanks Guys!
From what I have found from there website on the PAC 1518 Beehive springs the weight is 75 grams.
Charles Cyrus
07-19-2012, 06:53 AM
Premium Nitrided Beehive Spring
View Products $199.99Part Number: PAC1518
Brand: Scoggin Dickey Parts Center
SKU: PAC1518
Price: $199.99
Premium Nitrided Beehive Style Spring from Pac Racing Springs. Can use Stock locks and retainers from any LS head. Rated to .650 Lift by Pac.
Outside Dimension:1.290
Inside Dimension: .885
Max Coil Bind: 1.080
Recommended Installed Height: 1.800
Max Rated Lift: .650
Load @ 1.800 - 130lbs
Load @ 1.150 - 337lbs
Spring rate - 313.3 lbs/in
Spring weight - 62 grams
Spring Frequency - 29277CPM
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
