Aftermarket oil pan options?
Old 05-25-2012, 01:09 PM
Black Sunshine/ 00SS's Avatar
Default Aftermarket oil pan options?
Looking for something other than stock, a direct replacement. Prefer something I can weld a return drain on, for a turbo setup. Going on an 01 f body.
Old 05-25-2012, 08:35 PM
Gray86hatch's Avatar
moroso aluminum pan. It is the best
Tim
Old 05-26-2012, 06:30 AM
That's MISTER MODERATOR
Paul Bell's Avatar
^ agreed
Old 05-26-2012, 09:30 AM
Doesn't that require relocating the oil filter?
Old 05-26-2012, 11:48 AM
Yes all the moroso stuff does. It is worth it in oil control.
I like having the filter where I can change it without jacking the car up. plus you can get a bigger filter on the engine
Tim
Old 05-26-2012, 04:10 PM
Paul Bell's Avatar
^Also agreed! Get a remote filter mount with the 13/16"-16 spin-on filter thread and you'll be able to use the original small block/big block bigger sized quart filter. Keep all your lines -10 sized for less restriction. The Aeroquip AQP socketless hose is light and doesn't need expensive fittings.
Old 05-26-2012, 04:38 PM
I run the stainless braided on fuel and oil lines where there in a chance for rubbing. Even a remote chance.
My water lines are black braided.
On a daily driver car I like the holley pans
Tim
Old 05-27-2012, 12:45 PM
Any pics of the Morosso setup with placement of remote filter? Def not a daily driver.
Old 06-05-2012, 12:57 AM
93camaro_zzz's Avatar
I am interested in this as well. This moroso setup sounds kind of expensive.
What are some options for a budget replacement? I just got done finding stock LS1 fbody oil pans FS on here for like $230. Wtf is that?
