Generation IV Internal Engine - Clearance Measuring
View Full Version : Clearance Measuring
Wnts2Go10O
05-25-2012, 03:08 PM
getting block back (finally) very soon so i wanted to ask (after a search mind you)
all i have is a dial gauge in .0005 increments, a set of 6" calipers, and 3-4 sets of feeler gauges (lol). plastigauge seems to be out of the question. so.. the question is.. would i be able to do this assembly with the measuring tools i have (accurately)? this is for the budget build i am doing.
crainholio
05-25-2012, 05:20 PM
No micrometer?
Wnts2Go10O
05-25-2012, 05:37 PM
No micrometer?
nope, unfortunately
3rdCoastPowerSports
05-25-2012, 06:05 PM
Since you dont have all the right tools why dont you want to use plastigauge to check?
I know it is NO WHERE near as accurate but if you use Plastigauge properly it will tell you if you are in the ballpark
RezinTexas
05-25-2012, 06:43 PM
this is the one I got
http://www.amazon.com/dp/B0006J42CW/ref=biss_dp_t_asn
Wnts2Go10O
05-25-2012, 06:50 PM
actually, question, why would calipers be inaccurate for measuring outside diameter?
well, after a bit of reading it looks like plastigauge can be WAY off even when used correctly
3rdCoastPowerSports
05-25-2012, 07:41 PM
Calipers are not a replacement for a micrometer. too easy to mess up the measurement (i.e twisting, squeezing).
Before i bought a mic and bore gauge I would have my machinist measure the clearances then i would verify them with plasti... it was always right there with the machinist measurements. now i have a dial and mic so no more plasti
