American Torque Thrust 17x9.5
Can I run 315 on rear without modifications of rear wheel? Which tire can I run without it rubbing? Thank you
Going for looks more than anything else not a daily driver only bolt ons nothing special
That wheel is too small for a 315. Yes, it can and has been done but not recommended. Wheel offset and suspension are key factors in fitting the 315's. Stock height or lowered?
Cause i am a cheap *** and wanted the 315 rear look thats why.....didn't care about whole tire performing....anyhow thank you guys for your time it's awesome to be able to ask questions and get answers
We all want to get away with as "inexpensive" as possible. Cheap=dangerous. There are only so many corners you can cut. A failure of the tire, wheel, fender, etc is not worth the price.
At stock height you can get an 11" wheel with a 50mm offset and run a 315 without any other mods to the rear.*
*usually every car is a little different
