Gears & Axles - Differential noisy in turns.
gregfire
05-26-2012, 11:20 AM
My LT1 96Firebird makes noises from the differential, ONLY after it gets hot like a 30 min drive on the interstate with 70MPH.
and ONLY in slow tight turnes, like going in slow turns with parking the car.
after the car sits a while and in City driving i dont have this noise.
I will check the fluid level. there is a leak but not dripping.
anyone with the same experiences??
LT1 with 150,000 miles.
Greg
1ltcap
05-26-2012, 11:22 AM
what kind of noise? is it like a moaning sort of? can you tell whereabouts? from the center section? or out near one of the tires?
to be honest, with the little info, it sounds like a possible problem with the clutches in the diff.......
therabidweasel
05-26-2012, 12:42 PM
If its pretty quiet you could just need to change the fluid.
gregfire
05-26-2012, 01:33 PM
yes it is a moaning noise i think from the centersection
why does the noise come only when i drive faster for a while? during slower driving it will not getting noisy!
gregfire
05-30-2012, 09:45 AM
I am going to change the oil. i got normal Valvoline 75/90 oil Which says limited slip. Nevertheless a bottle of Limited slip.additive from GM is necessary with my Stock differential G80 code I guess.
Greg
HoLLo
05-31-2012, 08:18 PM
I agree changing the oil in it would be the first step.
aquariussuperman
06-01-2012, 11:03 AM
It sounds like it's sticking after it gets hot. Try adding 1/2 oz of friction modifier until it goes away. If both tires still lock up under hard acceleration, you have found the perfect amount of modifier. Do not over-do it.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
