98 LS1 T56 (disassembled)
Category: Accessories
Price: $600
Location (State): MS
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
1st, 2nd, 3rd, 4th, 5th, 6th, and reverse drive gears all in GREAT condition. No chips and the dog teeth have almost zero wear.
The mainshaft has a little heat discoloration on the shaft where the cluster gear was at. I had the heat the cluster gear to get it off so it colored the mainshaft a bit.
The main case and the tailhousing are in great shape.
I have all of the other small parts such has the shift forks and syncros, but the only syncro I would use would be the reverse.
I have all the bolts for the trans as well all labeled in zip lock bags.
UPDATES:
The trans was complete minus the cluster gear from the beginning. So if its not listed as SOLD below, I still have it!
Bellhousing- SOLD
Midplate-SOLD
Hydraulics-SOLD
Sensors-SOLD
Input shaft-SOLD
Thanks for all the interest guys! The midplate has sold and a few other parts are PENDING locally and on this site. Let me know what else you need guys. Will be moving within the next few weeks!
Bellhousing and VSS are sold!
