View Full Version : Why is there coolant leaking here? Video inside
konceptracin
05-26-2012, 11:06 PM
So went to help a buddy swap his headers and coolant started to piss out the exhaust stud holes, heads are l92 that just had a valve job done....any ideas?
konceptracin
05-26-2012, 11:12 PM
Check out this video on YouTube:
http://www.youtube.com/watch?v=61hovnQv8Ho&feature=youtube_gdata_player
Sent from my iPad
Jablowme
05-26-2012, 11:39 PM
was that before you put a bolt into the hole ?
would say u need a new head
konceptracin
05-26-2012, 11:42 PM
Pulled the bolt seen some coolant leak out, pressurized the coolant system to make the video, and it's doing this on both heads
5w20
05-26-2012, 11:53 PM
where the heads checked before doing the valve job?
konceptracin
05-27-2012, 12:36 AM
Yes they were, just had them pretty much cleaned up.... They were working fine with nothing like this happening last year in a turbo tbss
sicksspeed
05-30-2012, 12:15 PM
At this point why not try using thread sealer on the bolts and see if it works. Maybe liquid teflon like what g.m. sells in tube. What do you have to loose?
