Mustang swap BRP mounts
Old 05-27-2012, 02:07 PM
dmracing's Avatar
Default Mustang S480 swap
Hers some pcs of my Mustang Coupe swap with the brp mounts
Only have one issue not the mounts faults. But my tall valve covers hit the brake booster
Its a LY6 with a Comp cam 227,235 duration with .614,.625 lift
Edelbrock Victor Jr
850 Race Demon
CTVS oil pan
VVT elinimated
Turbo 400/brake and Precision Industry 4800 convertor
3.90 gear
Looking to get into the 10'
Old 05-28-2012, 09:05 AM
usdmholden's Avatar
What headers are you going with? I'm interested in clearance of the BRP headers to the stock k-member.
Old 05-28-2012, 03:04 PM
Chrome_Rust's Avatar
Awesome! I am using my stock K-member also, but I am building my own mounts (free time at work....) One questions that I have is where did you get the AN steam hole fittings? Those things are trick!
Charlie
Old 05-28-2012, 03:14 PM
dmracing's Avatar
Charlie
There from here
http://www.krcpower.com/catalog_i112...l?catId=366482
Old 05-31-2012, 07:40 PM
dmracing's Avatar
Heres some from underneath
Old 06-01-2012, 12:41 PM
64post's Avatar
What oil pan are you using with stock K-member? What headers fit with stock K-member? Thanks.
Old 06-01-2012, 06:32 PM
dmracing's Avatar
Cadillac CTSV pan and BRP headers
Old 06-04-2012, 11:46 AM
usdmholden's Avatar
I'm debating making my own headers from a set of Macs or BBKs, but before I do, I was hoping to see some pics of your setup with the BRP headers. If they fit really nice then maybe it's just worth buying them since I plan to run the stock k-member initially.
Have you fit the headers in yet?
Does the steering shaft go through the header primaries?
How much space is between the rear of the pass side head and the firewall? With the mod motor engine mounts I suspect I will have between 1/2" and 3/4" space between the back of the pass head and the firewall.
Thanks.
Old 06-04-2012, 11:53 AM
dmracing's Avatar
The headers are on there way, I dont have them yet. Ill measure the distance between the head and the firewall for you
Old 06-04-2012, 01:10 PM
turbo.trex's Avatar
Nice set
I'm doing one for my wife a coupe with GTO 6sp 6.0
I'm keep my eye your build..
Old 06-04-2012, 10:45 PM
Gregamuffin's Avatar
how much are just the mounts if you don't buy the whole kit?
Old 06-05-2012, 01:10 AM
LS102ws6's Avatar
looks good man
Old 06-05-2012, 04:10 AM
dmracing's Avatar
Mounts were $290
dmracing's Avatar
Originally Posted by LS102ws6
looks good man
Thank you
Old 06-07-2012, 08:30 PM
dmracing's Avatar
Put the transmission and passenger header in.
1 7/8 to 2 inch step header
Old 06-10-2012, 08:09 AM
johnyrrr's Avatar
I just finshed a LQ9 with a t56 in a 88 notch. That car is going to scream . where you at Dmracing, Im in South Lyon? Pm me if you want, high 10s should be no problem.
Old 06-10-2012, 10:50 PM
dmracing's Avatar
[QUOTE=johnyrrr;16402920]I just finshed a LQ9 with a t56 in a 88 notch. That car is going to scream . where you at Dmracing, Im in South Lyon? Pm me if you want, high 10s should be no problem.[/QUOTE
hows your car move? Hopefully, Ill get it in the 10's
Old 06-11-2012, 09:47 AM
johnyrrr's Avatar
Its got a decent cam and 243 heads, it runs very strong I think for a 6speed
Old 06-11-2012, 02:15 PM
trav-tech's Avatar
What this car a 2.3 or a 5.0 car? The v8 cars have a smaller brake booster that the 4 bangers do. Yours looks like the 4 cyl booster might just be able tp swap to the v8 one and not have your tall valve covers hit it.
Old 06-11-2012, 06:17 PM
dmracing's Avatar
how much smaller are they?
Quick Reply: Mustang swap BRP mounts
