General Maintenance & Repairs - Vapor canister purge solenoid
View Full Version : Vapor canister purge solenoid
brooksbowtieboy
05-27-2012, 04:01 PM
Check engine light has been on since I got the car it's a 2000 Transam 6 spd with 82,000 this is what comes up when I scan it purge solenoid malfunction I was just wondering if anyone else has come across this
RPM WS6
05-27-2012, 08:33 PM
I have not seen that code, but my purge valve did go bad and cause some idle issues. It was the final thing in a process of elimination which could have caused my issues, and once replaced everything was fine again.
So yes, they do fail.
1 FMF
05-28-2012, 10:09 PM
what kind of idle issues?
I have a 2002 with 61k miles, and the idle with clutch in seems a little rough sometimes, but the rpm gauge is steady at 800.
RPM WS6
05-29-2012, 11:13 PM
The idle would hang about 200rpm higher than commanded, and have a ~50rpm surge while doing so. IAC counts were at 0 and the idle was still high and surging. The obvious suspect was a vacuum leak, but the issue would be cleared up instantly with a simple restart of the engine (idle would return to correct speed without surge, and IAC counts would return to normal).
After trying a new IAC and a second EGR valve (not something you'd have to worry about with an '02) the only thing left that could cause an intermittent vacuum leak that could be cleared with a simple key cycle was the EVAP purge valve. I'm not sure why it never tripped a code, but I did this repair many years ago and the problem never returned.
This condition would usually only occur after long highway drives with sustained speeds above 50mph.
brooksbowtieboy
06-15-2012, 06:38 PM
Replaced evap solenoid on the driver side of the intake cured the problem I just didn't want to throw parts at it if it was another problem that would reaccur but thanks for the input guys
