New LS1 Owners - Newbie Tech - Name this hose!
98TransAmAngryBird
05-27-2012, 09:04 PM
I recently noticed that I had a snapped hose hanging in the back right side of my car. I noticed that this hose goes into the rear right valve cover see pics. Can anyone name this hose and where it connects to?? Is this some kind of vac leak??
http://i1068.photobucket.com/albums/u441/MEAST1525/IMG_1386.jpg
http://i1068.photobucket.com/albums/u441/MEAST1525/IMG_1383.jpg
http://i1068.photobucket.com/albums/u441/MEAST1525/IMG_1388.jpg
US_Army_Z28
05-27-2012, 09:34 PM
Does your air lid have a hole in the side on the right?
xFormulax
05-27-2012, 09:52 PM
No in 98 it didn't run to the air box. That hose runs to the AIR pump I think. The Air pump is that thing that sounds like a fan when you start up your car and it stays on for about 3ish mins. I think it warms up your cats or something. I might be wrong but thats what I always thought it was. I also think most people get rid or it when they run headers with an Off road Y pipe.
US_Army_Z28
05-27-2012, 10:00 PM
Yeah thats right 2000 and up iss when they started runnin to the air box. My bad i honestly have no clue what that one is. Buut it does llllok like what would run to the air pump thats why it was thhe first question to pop in my head
98TransAmAngryBird
05-27-2012, 10:23 PM
No I don't have a hole to the right.. I have a 98. Ill have to try and locate the AIR system.. I wish I could just delete the AIR and EGR, but being in california I am afraid Ill affect smog...
TImmy_Jones
05-28-2012, 09:17 AM
Wild guess; brake booster??
TrickrTreat
05-28-2012, 09:36 AM
Ok......The A.I.R. system runs hoses from the airpump and inject it to your exhaust manifolds....considering thats your valvecover , thats a No.
Its your Pcv system hose. starts on the front of intake , pass side , behind the TB. from there it goes down to the Pass side Valve cover at the rear, then crosses over to the Drivers side around the back to the point that you see broken in the pictures. And yes its a vacuum leak.
http://m.modmotortech.com/forums/showthread.php?t=1200416
Hope this helps.
98TransAmAngryBird
05-28-2012, 01:21 PM
Hope this helps.
Youre exactly right man!! thanks.
Juanmiguel
05-28-2012, 03:55 PM
x2 on the PCV. change the whole line if you can. most of it will be either cracked or broken. it's a vacuum leak waiting to happen.
TrickrTreat
05-28-2012, 08:35 PM
Just reread , my post.... WOW i sounded like a douche! Did NOT mean to come off that way. sorry about that.
Glad to be of assistance :burn:
My6speedZ
05-28-2012, 08:48 PM
PCV hose
I just helped a guy with this in another thread here:
http://ls1tech.com/forums/generation-iii-external-engine/1546939-broken-pcv-crossover-hose.html
98TransAmAngryBird
05-28-2012, 09:37 PM
Thanks trickrtreat for the real good info... and thanks my6speedZ for the legit write up. Man that is a solid method.. the stupid OEM pcv hose kit is like 135 dollars on ebay.. total rip off. Your method will last much longer too. good stuff!
My6speedZ
05-28-2012, 10:26 PM
Yeah and it's cheap too. Good luck and if you need any help PM me.
