New LS1 Owners - Newbie Tech - A/C delete
topgun542
05-27-2012, 09:28 PM
hey guys i got a quick question, Im deleteing the ac side of the heater core so does the system have to be sealed? im just wondering cause there was a hole on the bottom side of the ac so i was wondering if it needs to be sealled or not.
Nissan LS240
05-28-2012, 12:45 PM
First question are you removing for the room, or just ditching a/c to ditch it?
hole at the bottom is the a/c drain, the evaporator when it cools air it condenses the air and water droplets form on the evaporator and have to drain out, if you cut out the evaporator and leave a big gaping hole you probably won't have heat either, heater core and evaporator share the same blower motor so the blower will just blow air through the big hole instead of through your heater core
topgun542
05-28-2012, 03:26 PM
noo im making a cover plate for it, like the bmr block off plate, but leaving the heat. Im was just asking if it needs to be complety air tight
would anyone else have any comment or idea on this
bww3588
06-07-2012, 07:41 AM
It does in order for the blower motor to work at it's full potential.
When I deleted mine, I made a block off plate, and used seam sealer from an auto body supply store. It works like it was factory.
topgun542
06-08-2012, 09:07 AM
Okay i gotcha, im doing the same thing, i just noticed a hole in the bottom of the box right behind when i out the mounting strips. but anyway that answered my question! thanks!
Bsaint
06-15-2012, 10:04 AM
If you decide to sell the compressor and lines let me know :)
(as long as it was all working prior)
topgun542
06-15-2012, 10:39 AM
pm sent! and they worked to my knowledge! lol
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
