lncboytre_d
05-28-2012, 02:57 AM
Considering it's a 10 bolt rear end, are there any advantages on using Motive Pro Series vs Standard Motive Gears?
http://www.summitracing.com/parts/MGR-G975390/
ssvert99
05-28-2012, 10:03 AM
Pro gears(9310 alloy) are softer and meant for track use only, you don't want that gear if you drive on the streets at all.
You probably want their street type(8620 alloy)"Motive Performance". Part number there should be G875390. G=GM rear, 8= 8620 alloy, 75= 7.5" ring gear diameter, 390= 3.90 ratio.
Ethan[ws6]
05-28-2012, 11:59 AM
Yes^ stay away from 9310 for street use. It can't handle the long term use.
lncboytre_d
05-28-2012, 05:13 PM
Thanks for the help fellas.
