5.3 swap running pig rich
Old 05-28-2012, 11:15 AM
badhombre's Avatar
Default 5.3 swap running pig rich
just fired up my 5.3 swap for the first time and it is running incredibly rich. I am planning on converting it over to open loop speed density so I have no maf and have removed all of the factory o2's as I will just be running a wideband. it will be going turbo soon. anyways, to start it I have to hold the throttle wide open. when it does start it pours black smoke like a diesel and won't idle, I have to keep giving it some throttle. my friend was trying to set a baseline tune on it with hp tuners and just couldn't pull enough fuel from it to get it down. I actually ended up opening a vacuum port and it would somewhat idle. it would surge like a blown alcohol motor then. what am I missing here?
Old 05-28-2012, 12:36 PM
salemetro's Avatar
Might help if you could post your tune file. Also list any pertinent mods like cam, intake, TB, Injectors....etc....
Old 05-28-2012, 03:11 PM
badhombre's Avatar
motor is a bone stock junkyard pullout from a 99 silverado, harness and pcm from 01 yukon. harness was just stripped down to stand alone via the diagrams and instructions on lt1swap.com. and initially he just turned off the VATS, and all the codes for the items that were removed. I knew it would probably be a little off, but not this bad. he also said it was still getting one code though, a bank 2 injector control. what could cause this code?
Old 05-28-2012, 04:40 PM
badhombre's Avatar
after doing some searching the ECT has a large influence on the fuel trim. for some reason mine is reading -38* this probably has something to do with it I'm guessing?
Old 05-28-2012, 04:50 PM
salemetro's Avatar
Also make sure that you dont have an l59 running on an lm7 tune. The l59 injectors flow MUCH more than the lm7 injectors.
Old 05-28-2012, 06:38 PM
BLK02WS6's Avatar
Coolant temp sensor or wiring harness... it is commanding 9:1ish AFR at -38*
Old 05-28-2012, 09:20 PM
badhombre's Avatar
hmm... interesting I will have to confirm which injectors I have. I think I have the issue dialed down to the ECT. I traced the wiring but found no issues. checked grounds etc. problem is it's hard for me to tell if I make a difference now because my friend isn't here with the HPtuners to see if the ECT is reading or not if I change anything. IAT sensor was also reading -38* but I don't have an IAT sensor on it right now so that is to be expected I guess. going to double check the wiring and such again to make sure i didn't miss anything
Old 05-29-2012, 06:56 PM
BLK02WS6's Avatar
You'll be needin one of those too...
Old 05-30-2012, 12:38 AM
badhombre's Avatar
tried to rob the one off my t/a to test it with but discovered the plugs are different. guess I gotta find the truck sensor
Old 05-30-2012, 07:38 AM
Old Geezer's Avatar
Trying to diagnose this mess and you have all kinds of inputs that are fubar???
Old 05-30-2012, 10:25 AM
BLK02WS6's Avatar
LOL - newsflash - EFI engines don't run too well with half of their sensors missing
Old 05-30-2012, 11:16 AM
badhombre's Avatar
only one sensor is missing so I kinda of expected it to be a little off. but no to the degree it is. and I still can't find a reason why the coolant temp sensor shouldn't be reading. I mean the truck won't even start unless it's at WOT and then it struggles to stay running after that
Old 05-30-2012, 07:23 PM
BLK02WS6's Avatar
Better stop running it till you get that fixed or you are gonna wash the rings...
Old 05-30-2012, 08:10 PM
bwkmaro's Avatar
well you took off the o2 sensors which would be a fall back for the ect sensor so the computer litterally has no idea whats going on at all... what was your injector duty at idle like 60% haha
Old 05-30-2012, 11:20 PM
badhombre's Avatar
yeah it only runs when he has the comp on it so I don't damage anything. I want to be able to see what it's doing. not having the IAT plugged in won't make the coolant temp not read will it? I can't find any reason why it shouldn't be working. I have been kicking around the idea of throwing a pair of 02's back on it in the y pipe before the turbo. the injector duty at idle was around 20, but a quick blip of the throttle would set them to 96%
Old 05-31-2012, 01:08 AM
badhombre's Avatar
omgwtfhax...
so I decided, oh I'll just reconnect my bank 1&2 sensor 1's to the harness and use m y stock ls1 manifolds and y pipe for now to get it basically running. then I discover that for whatever bastard reason my harness uses a different upstream harness. it has a gray wedge shaped connector instead of the traditional square, and lt1swap.com shows they wire in differently as well. damnit, now I have to got buy a different set of o2's to put it back to closed loop. GM why can't you keep things the same and consistent? what the hell was gained by changing up these sensors?
Old 05-31-2012, 01:14 AM
itsslow98's Avatar
The ECT sensor will command a **** ton of fuel to warm the motor up. Get that fixed and I bet it makes a huge difference.
Old 05-31-2012, 01:30 AM
badhombre's Avatar
i'm working on that now, however my information seems to be conflicting. according to the wiring schematic, the ECT sensor loops from the PCM (C1 pin 74 yellow wire) through the sensor back to a low reference which by the schematic says should be C2 pin 80 gray wire. the wire from the sensor is gray, but on the same site the PCM pinout shows no such low reference back to the pcm, and both C1 and C2 have different wires assigned to pin 80. I also confirmed this with my pcm, it matched the pinout. so, where does this other gray wire go to?
here is what I am going by:
http://www.lt1swap.com/pictures/fig_2.gif
http://www.lt1swap.com/99-02_vortec_pcm.htm
Old 05-31-2012, 01:47 AM
badhombre's Avatar
dammit.... found the problem... found another diagram showing where the gray wire ties in. apparently it ties in to C1 pin 41 which is listed for a trans sensor ground. thinking I wouldn't need this I swapped it over to pin 42 like it says to be able to add in an electric fan control. I know what I have to do now but not looking forward to doing it....
Old 05-31-2012, 08:29 AM
Old Geezer's Avatar
Lightbulb Yep...
Some folks are still trying to disprove the theory!!
Quick Reply: 5.3 swap running pig rich
