Crank options for a LM7
Old 05-28-2012, 01:19 PM
King Nothing's Avatar
Default Crank options for a LM7
I'm looking at my options for a crank in a LM7, size and brand and why. I'm going with a 3.898 bore so it will at least be a 346ci. Motor will see boost btw, 8-12lbs and with have 317 heads and I'll run 9.5:1 compression
Old 05-28-2012, 01:25 PM
Blk98Vert's Avatar
Rebalance the stock one with the new rotating assembly. They are good for over 1000 at the flywheel
Old 05-28-2012, 05:21 PM
i've thought of that but if the shop ***** up on rebalancing the crank and the engine goes to **** i'll be very unhappy. i can have it looked at i suppose or i could go with a 4" if i want a 383 hmmm
Old 05-28-2012, 05:48 PM
MikeFSKSpeed's Avatar
If interested I deal with Manley, Lunati, and Crower for forged high quality Cranks!
Old 05-28-2012, 05:55 PM
pm sent
Old 05-28-2012, 07:56 PM
remauto1187's Avatar
Have you dont this? If so how much did it cost.
I would think that it would be very expensive since they would have to ADD mallory metal and alot of it to rebalance for a substantially higher weight piston.
Old 05-28-2012, 09:14 PM
S10xGN's Avatar
Hmmm, I would think an aftermarket piston would be lighter than a factory slug, and either way not enough to make a substantial difference in bob weight...
Old 05-28-2012, 09:23 PM
bww3588's Avatar
Depends. When I had a stock 5.3 crank balanced I believe the forged pistons of the larger bore (3.838 vs 3.780) were very close to the stock weight of the 5.3 pistons...closer than stock vs stock anyways. I was charged 150 bucks to re balance.
Old 05-30-2012, 08:02 PM
chrisfrost's Avatar
Yes stock LS1 pistons vs. LM7 pistons not very much difference maybe 2 or 3 ounces total difference .
Old 05-31-2012, 06:59 PM
driver56's Avatar
That's pretty substantial since 1oz is roughly 28 grams, we balance rotating assms. to less than .5 gram on a Hines computerized balancer.
Quick Reply: Crank options for a LM7
