Anyone running a 224/224 112lsa cam still with or without heads?
Old 05-28-2012, 03:48 PM
CJDZ24_Z28's Avatar
Default Anyone running a 224/224 112lsa cam still with or without heads?
I have a 224/224 112lsa cam and Livernois Motorsports stage 2 LS6's in my 98 z28 M6 along with all the bolt ons except a crank pulley. The car was tuned by a sponsor here but had a problem during tuning. The problem was corrected but i assume the car never went back. The car put down 379hp on a mustang dyno. During cold starts or even fresh starts I have to let the car warm up a little or it will want to stall. I say this shouldn't be happening with such a small cam especially since i owned 2 other lsx vehicles with bigger cams. Anyway anyone still run a cam this small alone or with heads? I'd appreciate seeing your numbers. thanks
Old 05-28-2012, 07:41 PM
DSRE's Avatar
Those numbers seem low for HCI, and it sounds like you are lean at cold idle, you still need more drivability tuning, i would expect at least 410-425rwhp imho
Old 05-29-2012, 04:47 PM
02BLK/BLKZ's Avatar
I am running a 224R on 112 with stock 241 heads and have no driveability issues. I do however let the car warm up before driving, if I don't I notice some idle surge with the clutch in and slowing down. When I let the car warm up I have no surge at all, I attribute this to the O2's not being warmed up. My car put down 366/367 through an LS7 clutch and aftermarket ZR1's, it is by no means a dyno queen. I have taken it to the track a few times on hard street tires and with an average 60 ft of 2.6X (horrible) the car traps 113-114mph consistantly. I hope this helps some, take it to the track and see what it can do dyno numbers don't mean a whole lot.
Old 05-30-2012, 05:22 PM
CJDZ24_Z28's Avatar
Thanks 02, was this on a dynojet dyno and do you have headers??
Old 05-30-2012, 07:53 PM
02BLK/BLKZ's Avatar
Yes, I have American Racing Headers 1 3/4" with cats. As to the dyno I do not know for sure but I believe it was a dyno jet.
Old 05-31-2012, 01:46 PM
CJDZ24_Z28's Avatar
Thanks alot for the reply. I'm pulling this cam out in a few weeks I have to make a few more ponies
Old 06-06-2012, 10:15 AM
motown2's Avatar
CJ don't forget that was a Mustang Dyno that those #'s are from. On a Dynojet it should read more. Also, I think the Livernois heads are meant for a little bigger cam and should shine once you throw that new stick in there. Keep us posted!
Old 06-06-2012, 11:40 AM
CJDZ24_Z28's Avatar
Yooooo! Yea i know the numbers were on a Mustang dyno but the car doesn't feel that strong to me. I had a cam only car that felt stronger. I have a 233/239 in my garage now ill keep you posted with the new numbers
Old 06-06-2012, 01:28 PM
motown2's Avatar
ITS A SMALL CAM. w/ THOSE HEADS, A 23X/23X OR GREATER I THINK WOULD BE BETTER. THAT IS THE SIZE OF THE STAGE 2 ON THEIR SITE.
Old 06-11-2012, 09:09 AM
LSX Mechanic
Damian's Avatar
Gonna move this to internal. You might get more responses there.
FWIW, your car will make 30-40 less HP on a loaded dyno than a regular dynojet.
Old 06-11-2012, 10:35 AM
gMAG's Avatar
For your stalling issue, check your idle air counts.
They should show between 45-75.
Quick Reply: Anyone running a 224/224 112lsa cam still with or without heads?
