ATI super damper LT1 install ?'s
My threads on my crank were kind of fubard from the previous owners hackjob. Never had any instructions when i got a used ati super damper. Had an extra set of hands one with a rubber/plastic mallet pounding it on while someone else tightens the bolt. Takes awhile but in my case i wouldnt trust pushing it on with a gun. Just too much stress and if my threads let go im FAWKED. Works for me and a bit of locktite for safe measure.
With an ATI it has a separate hub that you can just heat up and install. Put it in your oven to 200 degrees for 5 minutes or so and then grab it with a towel and just slide it on. Or you can borrow a balancer install tool. Either way, beating it on or drawing it in with the bolt is the wrong way to do it.
Thanks for the quick info on this install guys.
Noice,
I think I will try that trick with heating up the hub and put some anti-seize on the crank snout. Hopefully it will slide right on. Thanks for the tip. I was going to try and draw the hub down with the bolt, but it appears that is the wrong way to do the install. Where can I borrow a hub/balancer install tool? Maybe, oreilly's auto parts?
Noice,
Noice,
Noice,
I just installed my ATI damper this past weekend. The instructions included with the damper are very good. You also need to check to see how much of a press fit you will have by measuring the crank snout OD and the damper ID. In the instructions is a list of the range of low large press fit should be, which is important to how the crank transmits vibrations to the balancer. I used lots of anti-sieze and the boiling pot of water trick as well.
One tip I can think of,
If your installing the damper with the engine in the vehicle make sure you have the trans in a gear so the crank will not rotate, if your on an engine stand have the crank locked in place before you get started. Once you start pressing on the hub be sure to work quickly, the cool crank will pull the heat out of the hub quickly causing it to return to its original size fairly quick. The further the hub is on the crank the more resistance it will have and harder to keep moving until it bottoms out.
heating hub, anti seize all good tips
IMHO if you can find a Kent Moore "LT1" tool on ebay it is worth it. With the ATI though you will need a big (2") grade 8 washer since the hub hole is bigger than a stock one and the washer included with the KM tool is to small. Also need to use a socket over the "removal" part of the tool to get it off as a spacer...no big deal.
With the KM tool I don't heat the hub, just use anti seize and it goes on very easy.
