DonMega1
05-29-2012, 11:27 AM
I have a chance to buy a 1998 Camaro SS. The paint looks great, and interior is great but the Im worried since the car body has around 160k on it. and the engine has around 100k on it. He is asking 9900 for it. The first question is what do you think this car is worth? Second, what should problems should I look for with this car? If you have any concerns let me know people. Im looking for something that could be used as a part time daily driver if needed. If i get the car I plan on changing out the 918 beehives and going to a double spring. Then down the road Ill put on either a Ls6 intake or if i can get deal on Fast intake/tb I will go that route. Also I plan on putting some TSP stg 2.5 5.3 heads and possible a new cam. I believe i would have to upgrade the injectors to maybe 36#. It dont know what it will do in the 1/4 or what the dyno, but it should be fun to drive.
Engine: New GM all aluminum LS-1 crate motor installed by dealer at 63,000 miles (M1 synthetic oil since) Fast Toys Ram Air, SLP Lid & Ported throttle body March 25% underdrive crank pulley Thunder Racing 227/224, .569/.563 114 Cam (hottest that will pass emissions) Comp 918 Springs & Titanium retainers Polyurethane motor mounts Ceramic coated long tube headers and custom 2.5" Y-pipe with cats QTP electronic exhaust cut-out (muffler bypass), Hooker 3" cat-back exhaust Xtreme Motorsports custom dyno tune (361 hp to wheels with unlocked converter equals 440 at engine) Runs 12.4 in the quarter at 110 mph on a 1.84 60' (Firebird)
Drivetrain: Professionally rebuilt automatic transmission (4 speed overdrive). Yank SS 3400/2.3 STR high stall lock-up torque converter. B&M transmission cooler Auburn Racer's differential (tight posi) 3.42 gears (best acceleration & highway compromise) Excellent chrome Z06 rims (17 x 9.5) Bridgestone RE750 tires 275/40R/17 (stock SS size) with lots of miles left
Chassis/Suspension (makes a huge difference): BMR strut tower brace BMR boxed & welded subframe connectors BMR tubular lower control arms BMR panhard rod Adjustable torque arm Bilstein shocks all around Stiffer springs & oversize anti-sway bars (factory SS pkg) with Polyurethane bushings Slotted and cross-drilled rotors with Hawk HPS pads & painted calipers Electronic line-lock
Interior: Excellent condition (see below) Factory option Monsoon CD stereo system Nice tan & perforated black custom leather interior SS floor mats T-tops with factory matching shade inserts All power options, Cold AC, everything works Recent window tint (perfect condition)
