New LS1 Owners - Newbie Tech - Newbie question I'm sure-- Installing just Headers?
xxKennyDxx
05-29-2012, 06:33 PM
Hey guys,
Well, I am so undecided on which route I will be taking after headers (traditional cat-back with y or TD).
My question is....could I just buy myself a set of TSP headers (probably the 1 3/4ths, as I am not looking to do any "major" engine mods), and install them alone? No aftermarket y or catback-- just the headers?
I would buy a Frost tune to put after installation-- my question is: Is this possible in terms of taking the stock manifolds off...replacing only the manifolds-- bolting back on car, or do I have to buy a new y-pipe?
Sorry for the newbie post, I'd rather gain some power through the headers and worry about the rest of the exhaust later (if that's even feasible)
Thanks,
Kenny
jaxcam02
05-29-2012, 06:53 PM
I don't think there are any headers that connect to a stock y pipe. Im sure you could make it work but in the end you might as well go with a whole new exhaust from front to back. I'm sure the catalysts need to be replaced (or you just might go with the ORY) and the stock muffler can be improved on (unless you have the SLP dual/dual muffler). But I would find a good 3" single to dual 2.5" system and then get the tune, not much need for much more. Just a heads up, if by some godly force you think keeping the stock Y is your best you are most likely going to break a few bolts taking the old hardware off and if it gets stuck in one of the mounts your going to have to buy a new y pipe anyways.
projectX
05-29-2012, 07:06 PM
It won't work. You'll have to get an aftermarket Y pipe - everything after that will slide together no problem. If I were you I would just get the Frost tune while your doing headers so you can get it back after your done with the install - ready to go. ;)
xxKennyDxx
05-29-2012, 07:23 PM
Haha, thanks guys. That's what I figured.
Just wanted to see if I could get away with it the cheaper way LOL. Now the big decision, y-pipe to catback or TD's....hmm...lots of reading to do LOL
JUSTINSWS6
05-29-2012, 07:27 PM
Go td no rasp and sound better like a true muscle car. You could get tsp true duals kooks true duals or have a shop make true duals
TyCZ28
05-29-2012, 10:28 PM
BBK longtubes with Y pipe fit amazing, no leaks, and 350 shipped for headers and y pipe =] and SHINYYY
JUSTINSWS6
05-29-2012, 10:31 PM
Bbk are hit and mis on fitment. Also there y pipe merge is what gives the exhaust bad rasp flowmaster has good merges. With anything on a car you get what you pay for
I8UR4RD
06-06-2012, 06:19 PM
the y pipe has a nack for banging up under the drivers side. you will have to heat it up probably and smack it a few times, or buy some bumpstops from thunder racing. heat shields for torches work pretty well too
