General Maintenance & Repairs - E break is out?
View Full Version : E break is out?
Alberto v05
05-29-2012, 06:54 PM
How much would it cost to fix an e break on my 1999 z28? Thanks for the help
projectX
05-29-2012, 07:01 PM
If the e-brake cable is broke prob just 20-30 for a shop I would think. But is you need pads I'm not sure. Call around and ask some places locally. :)
JUSTINSWS6
05-29-2012, 07:04 PM
What do you mean its broke? Handel broke off? Did you cut the emergency brake line?
Alberto v05
Thanks, i think its the pads cause it makes a noise when i drive and the e break light is on the cluster and the ABSINOP light is on to
If you pull the hand break car won't stop?
JUSTINSWS6
05-29-2012, 07:13 PM
Will it slow it down any? And do you have a manual?
Alberto v05
05-30-2012, 12:32 AM
No does slow it down at all and yes m6
JUSTINSWS6
05-30-2012, 08:05 AM
Brake padd then because i think thry self adjust so you shouldnt have much slack.
nomasterase
05-30-2012, 10:39 AM
The e brake on these cars does not self adjust they must be periodically adjusted and since most people dont bother they get way out of adjustment. My 02 didnt work when i bought it but once i pulled the rotors they looked brand new. I just adjusted the hell out of em and they worked fine. I believe you have a couple of issues though because the e brake needing adjustment will not cause an abs light. Abs problems will however cause the brake light to illuminate. Id adjust the e brake for sure and then troubleshoot the abs problems
JUSTINSWS6
05-30-2012, 11:01 AM
How do you adjust them take off the brakes then rotors. Is there something under there to adjust?
nomasterase
05-30-2012, 12:59 PM
Yes there is a star wheel adjuster that sits in the opening of the e brake pad and one end of it is threaded into the housing just use a flathead to turn it a little at a time checking periodically to make sure the rotor still fits. Kinda hard to explain but once you see it its fairly self explanitory
JUSTINSWS6
05-30-2012, 01:35 PM
Is it on both back brakes or just the passenger side?
nomasterase
05-30-2012, 02:14 PM
Its on both located on the bottom of the e brake backing plate beneath the axle flange
eb110americana
05-30-2012, 08:52 PM
Yeah, there is basically a drum brake inside each of the disk brake rotor hats at the rear. The main difference is that instead of 2 shoes, there is only one giant horseshoe with a gap at the top for the starwheel adjuster and ebrake actuator. The horseshoe flexes to press outward using the two pads, one glued on each side.
Alberto v05
05-31-2012, 07:37 PM
i think its the brake pad too but I'm going to find out soon
Your right, I'm going to get it checked soon
