General Maintenance & Repairs - Rear Hatch Strut Replacement
NVUSZ28
05-29-2012, 08:13 PM
Can anyone send me a diagram of the struts for the rear hatch, on how to replace them.
Thanks
BadBirdie
05-30-2012, 01:31 AM
use a T50 torx socket to unscrew them from car and a small flat tip screwdriver to pry the release clip that ataches them to hatch.
sjsingle1
05-30-2012, 11:26 AM
unclip the one in the rear FIRST.....before you unbolt...........ask me how i know
BadBirdie
05-30-2012, 01:47 PM
how do you know?
transamtom
05-30-2012, 02:28 PM
Use a broom handle to hold the hatch up and do one side at a time.
That MOFO is heavy.
sjsingle1
05-30-2012, 04:21 PM
the pressure will make the bolt hard to get out and strip the threads
vatechguy3
07-18-2012, 06:26 AM
where is the best place to buy replacement struts?
tony
LS1121
07-18-2012, 11:10 AM
any auto parts store.
sjsingle1
07-18-2012, 03:20 PM
rock auto is the only place i found to get TA struts.....every place else just has base fbird struts
IceHammer
07-19-2012, 08:34 AM
Are there different ones for T/A? I can't see the hatch weighing more my a significant amount....
johnp94
07-19-2012, 09:08 PM
Trans am ,firebird and camaro struts are all the same. They hold up the same rear hatch that holds up the same weight. Forget the broom stick and find someone to hold up the hatch because you can get seriously injured if it falls. Take off top plastic molding that runs along top of the interior. unscrew if it is a ttop or pull off if it is Hard top. Put a flat head screw driver in the clothes hanger and pry the square plastic out of the hanger. pull the side plastic back to get to the rubber piece that covers the rear hatch strut. Go to the rear of car to take the metal pin out of the strut with a flat head screw driver. Try to pry it out without removing it it will make it easier. while someone holds the hatch up. Then go back inside the car to unbolt the hatch bolt. Take it off and replace that one with new one. Then repeat the steps for the other side. To replace the clothes hanger you have to put the square head plastic piece a little in the hanger then put into the body of vehicle. Hope I didn't forget any info.
BadBirdie
07-20-2012, 12:42 AM
ebay!
sjsingle1
07-20-2012, 03:07 AM
yes...........the TA and base fbird struts are different...........the wing does weigh more
vatechguy3
07-23-2012, 08:49 AM
Do you need the t/a part for the SS camaro and its heavier wing?
Also how does the strut get pulled through the rubber?
Tony
vatechguy3
07-26-2012, 11:56 AM
Anyone?
sjsingle1
07-26-2012, 12:30 PM
that rubber thing does stretch.......use wd40
Vetal
08-15-2012, 09:06 AM
So are hatch struts different for Camaro/Firebird/TransAm?
goldylocks
08-15-2012, 05:07 PM
pretty sure theyre not as I used camaro struts from the junk yard on my trans am hatch hold it no problem
great421
08-17-2012, 04:19 PM
Different weights; the TA deck is about 13 lbs heavier (if I recall right) than a Formula, and different PN's - if you have a TA with a raised rear wing, a "standard" strut will work, just not as well in cold weather, or for as long.
(Get the correct strut.)
