Drag Racing Results - LQ9 Fox First Time Out
Ls_Notch
05-29-2012, 08:46 PM
Took my mustang out for the first time last friday to make some shake down passes. Pulled hard on top but my 60ft was hurting due to some wore out slicks, good thing there is jegs :) Pretty basic setup just wanting to see what it will do before I put some new heads on it.
Setup:
86 fox gutted with 10 pt cage and sub connectors
stock 6.0 with 317s
ms4 cam. prc 650 springs
vic jr
kooks 1 7/8 3.5 long tubes
qa1 coilovers with rear sway bar
aje k member
28x10.5 mts
glide with a 3500 ptc stall
60- 1.70
330- 4.79
1/8- 7.34
1/8 mph 96
1000ft- 9.55
1000ft mph- 110
1/4- 11.41
1/4 mph- 121
also have a new holly hp 850 on the way should be here friday, looking forward to better weather with a high of 68.
da last friday was around 3000 on a greasy track
ShifterLou
05-29-2012, 09:12 PM
Good to see! What gear do you have in the car?
I'm doing a 6.0 this fall.
Going to use PRC Stg 1 LS6 heads, FTI cam & springs, Cleaned up Vic jr, 1 7/8 long tubes
Will be in my fairly light 84 GT.
I'm shooting for 10's :)
Ls_Notch
05-29-2012, 09:31 PM
4.11s
I hope with some tuning and seat time I can see some 10s then it will be time for a 150 shot
ShifterLou
05-30-2012, 08:21 AM
Wonder if the glide hurts?
You have the trap speed to be knocking on the 10 second door. I've been 11.20's at 117 in my car.
My converter is A LOT looser than yours. Was your PTC built with the spray in mind?
richard david
05-30-2012, 11:20 AM
Get rid of the glide or go with a lot more stall. My conv.is 4200 and it is still not enough.
ShifterLou
05-30-2012, 12:38 PM
Agreed. I shift my car at 6,000 and the converter flashes to 5,200. I'd like it a hair tighter...but literally just a hair.
Ls_Notch
05-30-2012, 05:34 PM
Yea plan on spraying it. Id like to pull it out and have it restalled to around 4500 but we will see once its on the juice. As for the glide I got a really good deal on it rebuilt with a brake in it and couldn't pass it up.
ShifterLou
05-31-2012, 05:58 AM
I'd take a good deal on the glide too.
When I first put the c4 in, the very first pass on the trans brake I leg go of the button and accidentally pulled it right into 2nd gear, still went 11.65....and the other passes were all in e 11.55 range.
So even if the glide is giving up et....it isn't much!
richard david
05-31-2012, 06:26 AM
My 93 notch back is still 3100lb and with a stock bottom end ls1 and stock 243 heads went 10.71@126 so you should be able to get there. Also get a custom cam for a Carb. I had a off the shelf cam in mine and only went 11.36@119
HitmanLS1
05-31-2012, 10:44 PM
Who speced your cam Richard?
richard david
06-01-2012, 04:29 PM
Geoff at eps
06X6spdGTO
06-01-2012, 10:15 PM
Had the same problem with our regal, Glide/4200 stall and 4.56's. Keep the glide get a 5500rpm 8" converter.
Best we could get was 11.54@ 121.9 w/ 1.73 60' 5550ftDA
We've got a Coan 5600/5800rpm Converter on order for ours with the supersprag.
2985lb Raceweight (No Driver) 850 holley Carb
93camaro_zzz
06-07-2012, 06:47 PM
Nice run! What does your car weigh?
Ls_Notch
06-08-2012, 08:33 AM
Not sure I need to get it on the scales. Its got a fiberglass Hood and decklid with a stripped interior with a sheet metal dash so I bet its pretty light
Ls_Notch
06-12-2012, 08:49 PM
Took it out again last Friday with a new Holly HP ultra 850 and new slicks to see if it would do any better but only ran 11.6s. I couldn't figure out what was going on untill tonight I checked my throttle cable again and it was only opening around 1/2 to 2/3 of the way. I feel dumb for not checking that first, I bet the car will run a little better now :)
jgillen91
06-12-2012, 09:37 PM
I had same problem man went 12.16@110 in my carbed ls3 headed 370. Was getting 50% throttle. Fixed problem and went 10.96@124 lol
Ls_Notch
06-13-2012, 06:03 PM
feels better now :)
06X6spdGTO
06-13-2012, 07:53 PM
Keep everyone posted what you pickup with the 850 holley Ultra HP
